Volare subframe ID?
#155265
11/23/08 12:38 PM
11/23/08 12:38 PM
I'm rebuilding a Volare subframe for use in my buddies '55 F-100 Ford. This is evidently a popular swap to get rid of the factory straight axle. He found a place that sells cutting and welding templates for the swap and I have seen it before. Is there any way to ID the specifics (year / model) this came out of? Any major differences in parts? Im looking at replacing all rubber parts, brakes, ball joints,tie rods,etc. Any parts supplier recommendations? I have not torn into it yet but its pretty rough. Looks like it was out of a tired car and then sat outside for a while before he bought the project. Any help is appreciated.
Thanks, Pete
Re: Volare subframe ID?
#155266
11/23/08 01:07 PM
11/23/08 01:07 PM
Any NAPA/Auto Zone type parts house will have what you need. Order tierods/idler arm/b-joints, whatever, for any Volare....go with a 78, that'll work.
As for brakes....measure the diameter of the disc and order brakes from same place, for same year Volare. All front wheel bearings will be the same on the Volares.
I've seen this done a few times....it works out to be a nice front end package.
You're gonna love the sideways torsion bars and how easily you'll be able to adjust ride height on the new truck.
Sid
[Re: dynamite]
#155268
11/23/08 02:38 PM
11/23/08 02:38 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Just be aware that the torsion bar bushings are NS1 and there are no aftermarket replacements...so go easy on them when you disassemble everything. I'm 99% it's the end bushings, not the pivot bushings (which are still available). M-bodies (Diplomat, Fifth Avenue, Gran Fury, Town & Countyr, etc.) use the same front suspension as the F-bodies (Aspen/Volare), so you can always use used parts from one if needed. Don't forget to upgrade to larger diamter front disc brakes for better stopping. http://www.moparaction.com/tech/archive/disc-main.html
#155269
11/23/08 05:50 PM
11/23/08 05:50 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I did the same swap in a '55 F-100 years ago. You don't need the fancy templates. Just use coat hangar to copy the shape of the "K" member and transfer it to the Ford frame for cutting. After you find where the wheelbase should be, stock, the most important thing is to have the "K" member moved 1" forward. Failure to do this will make the wheels appear too far back in the wheel wells because you are also going to be lowering the truck. Believe it!!. Box the frame, install suspension and brake components, and you are good to go.
This is the land of the free
because of the brave
[Re: In_The_Pink]
#155270
11/27/08 09:12 PM
11/27/08 09:12 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
The end torsion bar anchor/bushings are available but a real @#$% to get off. They might look crappy around the outside edge but are probably OK anyhow. The pivot bushings are only available from the guys out west at Firm Feel I believe. And they do not have the dust shield like factory pieces which clamps to the bar to keep debris out from between the bushing and bar though.
