buzzing noise from speakers. MSD #155236
11/23/08 11:23 AM
11/23/08 11:23 AM
west palm beach, florida
modelmakerinc Offline OP
I hope someone has been there done that. I dont listen to the radio much when I drive, but I always have a annoying buzzing which changes with rpms from just the right speakers . Even with the radio off I have the buzzing
I have MSD ign. Is there a reason and cure for this? or could it be the speakers are damaged?
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: buzzing noise from speakers. MSD [Re: modelmakerinc] #155237
11/23/08 11:35 AM
11/23/08 11:35 AM
IN
ahy Offline
ahy  Offline
IN
It could be the ignition wires. What type are you running? Solid core would put out a lot of interference.
Re: buzzing noise from speakers. MSD [Re: modelmakerinc] #155238
11/23/08 11:36 AM
11/23/08 11:36 AM
I believe MSD sells a noise filter to combat this. Your speakers are fine.
Re: buzzing noise from speakers. MSD [Re: modelmakerinc] #155239
11/23/08 11:36 AM
11/23/08 11:36 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
How close are the MSD wires to speaker/radio wires?
I've had my MSD installed on my heater box for 3 years and haven't had any noise. You can try and twist any of the MSD and speaker wires to help keep down interference. What plug wires are you running? Alternator can also cause this issue.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: buzzing noise from speakers. MSD [Re: GoodysGotaCuda] #155240
11/23/08 12:11 PM
11/23/08 12:11 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
plug wires - get a set of quality spiral core wires - MSD 8.5mm Super Conductor, Taylor Spiro-Pro, Moroso Ultra 40, etc...
Re: buzzing noise from speakers. MSD [Re: Lefty] #155241
11/23/08 02:47 PM
11/23/08 02:47 PM
I do have a good set of wires (MSD 8.5mm Super Conductor) and the reason I didnt consider the plug wires is because I am only getting it on the right side speakers.
I will check my wires to see if they have any scuffs or damage. thanks
Re: buzzing noise from speakers. MSD [Re: modelmakerinc] #155242
11/23/08 02:54 PM
11/23/08 02:54 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
might be your alt doing this as well..
Re: buzzing noise from speakers. MSD [Re: Dakota_Don] #155243
11/23/08 04:16 PM
11/23/08 04:16 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
you need their noise filter,,,i have the same problem,,very annoying.
