parachute rule #1550757
12/20/13 11:06 PM
12/20/13 11:06 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
what is the actual nhra parachute..rule.. I ask ten people and get ten answer...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: parachute rule [Re: WHITEDART] #1550758
12/20/13 11:09 PM
12/20/13 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Has to be mounted on the car at 150 mph.. you dont have
to pop it
Re: parachute rule [Re: WHITEDART] #1550759
12/20/13 11:10 PM
12/20/13 11:10 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I always heard it was anything over 150 MPH.. except for motorcycles.
I am truckless..
Re: parachute rule [Re: 340SHORTY] #1550760
12/20/13 11:20 PM
12/20/13 11:20 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
NHRA is 135mph....IHRA is 150mph as far as I remember...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: parachute rule [Re: MR_P_BODY] #1550761
12/20/13 11:20 PM
12/20/13 11:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
to pop it
Used to be 135............glad that changed.............
Re: parachute rule [Re: Thumperdart] #1550762
12/21/13 01:10 AM
12/21/13 01:10 AM
Renton Washington
Triple Threat Offline
Renton Washington
150 mph across the board.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: parachute rule [Re: Thumperdart] #1550763
12/21/13 01:10 AM
12/21/13 01:10 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
According to the 2013 NHRA rulebook
Super Pro, Pro, Sportsman
PARACHUTE
Mandatory on any car that runs 150 mph or faster. See GeneralRegulations 4:8.
4:8 PARACHUTES
If outlined in Class Requirements, it is mandatory to have a braking parachute produced by a recognized drag racing parachute manufacturer. Dual parachutes required for all cars running 200 mph or more. Tech inspectors may observe the proper operation of the parachute and inspect for worn or frayed shroud lines, ripped or dirty canopies, and worn or ragged pilot chutes. Parachute cable housings should be mounted solidly to frame tube or other suitable member no farther back than 1 inch. The release housing must be attached within 12 inches of the parachute pack and in a manner that will allow the inner cable to release the parachute. When supercharged or using nitromethane as a fuel, it is mandatory that the parachute pack and unpacked shroud lines be protected with fire-resistant material from the mounting point to the pack. Parachutes must have their own independent mounting with sleeved 3/8-inch minimum steel bolts or steel pins required for all applications unless otherwise stated in Class Requirements. Shroud-line(s) mounting brackets must be constructed of minimum .090-inch steel unless otherwise stated in Class Requirements. Safety pins must be red flagged and removed prior to burnout. The use of ball-lock pins for parachute mounting prohibited. See Class Requirements regarding use of two parachutes. Such applications require separate shroud-line mounting points for each parachute system.
