Re: Project 1972 D100
[Re: 69HemiGTX]
#1548733
12/19/13 05:16 PM
12/19/13 05:16 PM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
Good to see another of one of the most beautiful pickups ever made get some love.
Thanks.
The truck was bought way back when by my Grampa. My older late brother and I helped my Grampa work on her. So this truck has sentimental value. I'm doing a quick job fixer her up for now. Just to make her more dependable since I do drive her just about everywhere.
Gonna drop the $80 360 in there for now while I save to finish the other 360. Still need rods, and a flywheel for that 360.
No updates today. I feel ok. Not great, just ok, and its raining. So nothing till tomorrow
[Re: wally426ci]
#1548735
12/20/13 05:40 PM
12/20/13 05:40 PM
magnum440d100
woodcrest, CA
Check the frame around the steering box while you have easy access by pulling the bolts. I had 1 truck crack here.
Thanks for the tip. I'm not there just yet, but I do remember we had to drill 1 hole when we went to power steering. It wouldn't surprise me if it did crack there. My passenger side motor mount pad is cracked too.
I DO live on a dirt road. It is fairly maintained, but the tractor tires leave bumps in the road. And I do/did work construction where we were required to drive over cow grates to shake off the mud before we went out to the exit. I avoided them as much as possible.
I wonder if any of that contributed to any cracking?
I've been driving it for the past ~10 years, but we've owned it for about 20.
[Re: JDMopar]
#1548742
12/22/13 03:00 PM
12/22/13 03:00 PM
magnum440d100
woodcrest, CA
Looks like you're making good progress. If the oil pan that's on it is sealed up and working, why not use it? Is there a difference in a truck pan, and a van pan? The one off your 318 won't fit the 360. Inside of the motor sure looks clean!
The guy had to take off the oil pan to get it out of the RV/van. It sat in a garage uninstalled and rusted fairly bad inside. I have an extra stock 360 pan that I'll just put on, since I'll be going to an aftermarket pan for the built 360. This 360 is just going in because the 318 is done. It's still good/ok but needs to come out because I wiped a cam lobe and have been finding speckles in the oil. It's gonna come out and apart for an inspection. It's been rebuilt in 1999-2000, but should only have about 70k.
I also have a high volume oil pump I'll put in the 360 just because. I haven't had a good look at the oil pump on the $80 motor. It's been on the cherry picker and I just haven't had the guts to get under it and look haha
[Re: johnscudashop]
#1548743
12/22/13 03:19 PM
12/22/13 03:19 PM
magnum440d100
woodcrest, CA
Nice project. I always had a soft spot for these trucks..The van oil pan the sump is in the front ,the Truck pan the sump is in the back.. To you have a externally balanced torque converter or are you gonna weld on some weights ?
None of the above
Truck came as a 3 on the tree a230. But that was swapped for an A833od for gas mileage. I'm hoping the 833 hold up behind the 360. If not, I'll have to see about a 5 speed
For now, I'll order a flywheel from mazzolini because he's down the street from me and he's a great guy.
[Re: magnum440d100]
#1548744
12/23/13 12:00 AM
12/23/13 12:00 AM
magnum440d100
woodcrest, CA
Got the intake stripped primed and painted. I would have installed it, but paint is still fresh. Don't want it chipped by the bolt holes. Got the valve covers stripped. Have some detail work to do. Clean the crevices and straighten the holes. And yes I did reinstall some smog devices (egr valve) and thermostatic vacuum switches. Even though its going in a 72, once the race motor is built, this ones going in something else. I may just find me a 75-78 dodge shorty van Gettin there
[Re: magnum440d100]
#1548745
12/23/13 07:12 PM
12/23/13 07:12 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
looking good! that $80 engine looks pretty clean inside. That one pic reminds me I need a couple plug wire holders.
1981 Dodge D150 360 auto
[Re: magnum440d100]
#1548747
12/25/13 12:51 AM
12/25/13 12:51 AM
magnum440d100
woodcrest, CA
Pushed it out into the gravel driveway and went to scrubbing. Had to stop. After all, it IS Christmas Eve lol Found that both the motor mount ears on the Kmember are cracked. Pics later. This truck is looking like its going to need a K member bummer. Looks like its welded in.
[Re: magnum440d100]
#1828268
05/17/15 04:13 AM
05/17/15 04:13 AM
magnum440d100
woodcrest, CA
Have it semi assembled. Still no cab mounts. Saving up for them. Still have to run brake lines, etc, but need it rolling for when my house sells. Plus now I can get my other truck backed in to pick up the 360 to take to get balanced tomorrow, I may do the brakes (upgraded to 11" in the rear and need to get the pads/cylinders/spring kit, etc.
[Re: magnum440d100]
#2150174
09/08/16 05:09 AM
09/08/16 05:09 AM
magnum440d100
woodcrest, CA
Long time no update. Been busy and haven't gotten to the truck as much as I would like. BUT I got it running with a 318 for now. 360 build is going slow. I may assemble it soon but I'm waiting for heads. Been working on the 72 every day for the past few days. Got it running and moving. Still needs some loose ends handled: Strut rod bolts/sway bar bolts on control arm tightened Attach sway bar end links Wiring ran to tail lights Cab bolts tightened all the way. Left loose to lift cab for panel alignment Lube front end Run exhaust. Right now it's just open Y pipe Attach front bumper And anything else that I come across. But I drove her out of the spot she's been sitting in. Can't do any work on it tomorrow, but Friday till Monday is open season I can't wait hehe
