Dakota transfer case
#1548021
12/15/13 11:19 PM
12/15/13 11:19 PM
Posts: 1,487 STL
cdstl
STL
I had the driveshaft come off of my 96 Dakota. I had changed the u joints and a couple of days later one of the bolts that holds the rear u joint to the yoke had it's head break off. My son was driving but it sounds like thing went to hell pretty quick. Besides needing a new driveshaft the output shaft of the transfer case broke clean off.
I am going to get new, read used, parts and I want to know how tough it is to change the chain in the transfer case. I will also replace the front and rear seals.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Dakota transfer case
[Re: cdstl]
#1548024
12/16/13 09:50 PM
12/16/13 09:50 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
My bad. You can still change the rear output shaft in the case with just pulling the rear case half off. It pulls right out once the rear is taken off. It may be cheaper just to find a whole other transfer case though. Call Zumbrota bearing and gear for a good deal on the parts. They will be way cheaper than Napa. They should have everthing you need to fix yours. www.zbag.com
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#1548025
12/16/13 11:49 PM
12/16/13 11:49 PM
Posts: 1,487 STL
cdstl
STL
Thanks Jason. I had no idea it would be a simple swap for the rear shaft. I will probably be using a place up in Mt. Olive, IL called Mullins. I will just replace the xfer case since it's hard to tell what else might be wrong if there was enough force to rip off the shaft.
Since I first posted I realized that the chain in my current case is supposed to be new. I had it replaced when I had the transmission rebuilt.
