Re: 70 challenger key-in buzzer
[Re: BDW]
#1545692
12/12/13 12:43 AM
12/12/13 12:43 AM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
2 more questions:
- just plug in the buzzer and it should work, nothing to do on the column? - anyone find a substitute buzzer? I'm guessing it's hard to find an original?
As long as the column buzzer switch is intact it should work after it's plugged in...It's the small red/black wire set coming out of the column... Make sure the {key-in buzzer}case has a good ground to the dash frame...Post what you find and I'll help troubleshoot the system if you need help..
The buzzer is'nt hard to find there's more out there than you would think seeing how every car got one...
Here's a long winded thread from a while back with some great info about the dash wiring... LINK
[Re: dan9]
#1545693
12/12/13 01:03 AM
12/12/13 01:03 AM
screamindriver
Harrisburg, Pa.
May be related or not but looking at the steering column there is a yellow lead coming down from the upper part of the column. Is it safe to asume they go together as part of the buzzer system? thanks
... Not related...I'm betting you have the A01 light package and the yellow wire is the key switch illumination wire...check out the link I've posted above it shows the Ao1 wiring and the time delay harness that's needed for your yellow wire...Hopefully it's under the dash and simply unhooked..
[Re: screamindriver]
#1545695
12/12/13 02:01 PM
12/12/13 02:01 PM
Posts: 4,724 Florida
BDW
This buzzer wiring is not part of the main column harness? Just replaced my TS switch and don't recall a seperate harness?
Thanks for the info
[Re: BDW]
#1545697
12/12/13 10:24 PM
12/12/13 10:24 PM
screamindriver
Harrisburg, Pa.
Thanks for the info
Yes, sorry I've been working on too many vehicles lately and had a brain cramp...it is in fact part of the starter and ignition switch harness...it's the two red wires on the end of the flat connector...You could run a jumper between those two red wires to bypass the key switch as a test...And if all else fails tap the buzzer... ..No kidding some will come to life by doing that..
[Re: dan9]
#1545698
12/12/13 10:43 PM
12/12/13 10:43 PM
screamindriver
Harrisburg, Pa.
Thank you for the link. It helps understand the wiring diagrams better. My question is about the red and black "T" connector and the yellow wire with a round female connector. If i don't have headlight delay is anything supposed to be connected to these two plugs? One more question there is a yellow wire with a flat male connector coming down from the steering column. What is it for? Thanks for the help
Dan, here's a pic of the time delay harness with the round connector...Does your yellow wire with the round connector look like it would plug into the highlighted connector in the pic ??? Yes it would get connected without the headlight delay..
[Re: 70mopes]
#1545700
12/14/13 01:23 AM
12/14/13 01:23 AM
screamindriver
Harrisburg, Pa.
Yellow wire with flat male connector is for ignition light. There is a unique optical tube that sheds light onto the key.
It's a 1 year only piece but should have a round connector...Don't feel bad I get confused also when you don't deal with the wiring every day..And to be honest the yellow wire with the flat connector has me drawing a blank without more info.. ..My guess is someone hacked off the column connector for the key switch light and replaced it with a flat connector and the delay harness is still intact with the round connector...
Here's a pic of the 70 key switch illumination with the wiring connector...Connects to the highlighted connector in my previous post...At that point I was trying to determine wether Dan has the time delay harness in his wiring or if it's missing...
