Re: what rim to use
[Re: earthmover]
#1545546
12/09/13 01:00 AM
12/09/13 01:00 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
ok guys what size rims are better for me.. I plan to go to a 10.5/31 tire and looking at options as far as rims size goes..should I use a 10 rim or 8.....what are most you fast guys running ....also the wheels will be champion wheels does anybody have any input on them about fit whith wildwood calipers.. I read somewhere somebody had problems with fit but cant remember who or where I read it..
I've been lookin at the champions also,the website tells you how to measure it up.
http://www.championbillet.com/drag-wheel-technical-information/
Cap5 Black Wheel / XV Beadlock Black Double Cut / Gold Bolts
Black Cap5 With XV Beadlock $537.00 Choose Options
Speed Series Wheel Polished / XV Beadlock Black Double Cut / Black Bolts
Polished Speed Series With XV Beadlock $507.00 Choose Options
Cap5 Wheel Black / X Beadlock Black / Gold Bolts
Black Cap5 With X Beadlock $515.00 Choose Options
Speed Series Wheel Black / X Beadlock Polished / Gold Bolts
Black Speed Series With X Beadlock $515.00 Choose Options
Cap5 Wheel Black / Smoothie Beadlock Black / Gold Bolts
Black Cap5 With Smoothie Beadlock $515.00 Choose Options
Drag Wheel Technical
Prior to ordering your wheels, please verify your measurements are made according to the diagram below.
With double beadlock AND/OR wheels with a backspace larger than 4", there is a brake clearance concern. To check this, measure from the center of your axle out to the edge of your brake caliper in a straight line--if that measurement is less than 6.5", you should have proper brake clearance. Any more than that, and we recommend contacting us for further assistance.
Re: what rim to use
[Re: 6PKRTSE]
#1545551
12/10/13 01:06 AM
12/10/13 01:06 AM
Posts: 240 Spring City , Pa.
SIKPUP
Spring City , Pa.
We run a 12" with our 10.5s ! Seems to give a better footprint ! As for the wheels I don't have any experience with them !
Agreed, I run 12" rims on my 10.5"'s also. Currently my car has 315's on the car now. No beadlocks currently. Maybe someday.
Have any more pics from the rear of that 315 ?
