B-body disk conversion question- brake hoses #1545314
12/08/13 06:50 PM
12/08/13 06:50 PM
OK
David_Trimble Offline OP
OK
Hi-
I'm doing the B-body disk conversion on my '69 Charger R/T using spindles from a '77 Diplomat. Since my suspension (with the exception of the conversion, of course) is factory stock- meaning I have the '69 front sway bar configuration - I understand that I'm not going to be able to mount the spindles so the calipers are towards the front as they will interfere with the sway bar mounts.
Now in reading through the posts on the board I've seen a few examples where someone has mounted their calipers rearward, and I wanted to ask: can I use off-the-shelf brake hoses for that and if so from which car? Or would I be better off having custom hoses made?
Thanks!
David
'69 Dodge Charger R/T
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545315
12/08/13 06:56 PM
12/08/13 06:56 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
You using the "Slider" type of caliper?
If so, the hoses from Aspen's and Volare's work.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545316
12/08/13 06:59 PM
12/08/13 06:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't see what difference "pin" or "slider" would make. Anyhow, I got braided steel hoses from DR Diff.
Re: B-body disk conversion question- brake hoses [Re: Stanton] #1545317
12/08/13 07:01 PM
12/08/13 07:01 PM
hemi71x Offline
hemi71x  Offline
Hoses are differen't between the two styles.
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545318
12/08/13 10:31 PM
12/08/13 10:31 PM
Unless someone has done that swap & has a hose recommendation for you I'd get the calipers mounted & measure roughly how long of a hose you need then see if your friendly parts house will set some out for you. when measureing do so from lock to lock & with the suspension pulled all the way down & jacked up till the front wheels are off the ground. The hoses with the long metal collar on 1 end gave me the most trouble on an A body swap. the collar I am refering to is not the bracket in the middle of a volare hose it's on the end on some hose types
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545319
12/08/13 10:59 PM
12/08/13 10:59 PM
AndyF Offline
AndyF  Offline
Best way to do it is use calipers which are designed to be rear hung and rear fed. There is not a factory hose that works very well but DoctorDiff can get you what you need. (I covered this topic complete with pictures in my B-body book.)
Re: B-body disk conversion question- brake hoses [Re: AndyF] #1545320
12/10/13 10:38 PM
12/10/13 10:38 PM
OK
OK
Thanks, all. Yes I thought that maybe someone might've had the same configuration and was able to figure out what off-the-shelf hoses would work but it sounds like everyone in this situation went the custom route. I don't have the knuckles installed just yet but it sounds like I need to just get everything back together and get the measurements. I'll then contact DoctorDiff for some custom made ones.
Thanks!
David
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545321
12/11/13 12:37 AM
12/11/13 12:37 AM
AndyF Offline
AndyF  Offline
I think that DoctorDiff has found some Camaro lines that work. Best bet is to look at his website and/or call him.
Re: B-body disk conversion question- brake hoses [Re: AndyF] #1545322
12/11/13 12:40 AM
12/11/13 12:40 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
He only shows braided ones on his site. 68 GTO might be close as they are banjo style and are rear mounted.
Re: B-body disk conversion question- brake hoses [Re: moparpollack] #1545323
12/11/13 12:42 AM
12/11/13 12:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You don't need to give DR Diff measurements, just tell him the application. The hoses are braided steel though.
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545324
12/11/13 03:01 AM
12/11/13 03:01 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you run '80 and newer Diplomat (slider) calipers toward the rear, '69 Camaro hoses work perfectly.
Re: B-body disk conversion question- brake hoses [Re: DoctorDiff] #1545325
12/11/13 01:48 PM
12/11/13 01:48 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I did the F,M,J body disc brake conversion on my 70 Sport Satellite (manual drum to manual disc brake) . . . got the hoses from Doctor Diff - braided stainless steel . . . calipers mounted on back side, everything fit great and works perfect !! . . . Thanks again Cass !
Cheers
Mark
Re: B-body disk conversion question- brake hoses [Re: a12rag] #1545326
12/11/13 02:07 PM
12/11/13 02:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Aren't the hose mount locations the same on both the slider and pin style calipers ???
Re: B-body disk conversion question- brake hoses [Re: Stanton] #1545327
12/11/13 03:39 PM
12/11/13 03:39 PM
AndyF Offline
AndyF  Offline
Not necessarily. There are different hose locations on different calipers depending on the original application. I put pictures of different calipers in my B-body book so people could see the difference.
Re: B-body disk conversion question- brake hoses [Re: DoctorDiff] #1545328
12/13/13 09:54 AM
12/13/13 09:54 AM
OK
OK
The calipers are from a '77 Diplomat- but they appear to be slider types, though. Will the Camaro hoses still work?
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545329
12/13/13 12:24 PM
12/13/13 12:24 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't recommend mounting pre 1980 slider calipers toward the rear due to hose routing.
Re: B-body disk conversion question- brake hoses [Re: DoctorDiff] #1545330
12/14/13 06:32 PM
12/14/13 06:32 PM
OK
OK
Hmm.... well I'll try to swap the spindles so the calipers are forward, but from what I've read on the conversion I'm not too hopeful that I won't run into any interference issues with the sway bar. On the other hand I also seem to recall that not everyone ran into this problem- hopefully I'll fall in that category.
Failing that, my only other recourse would be to replace the front wheel hardlines with longer ones that will run forward of the wheel, and weld in new brackets for the hoses.
Edit - question: do I HAVE to run pre-80s slider calipers on a pre-80s steering knuckle? What if I get slider calipers from a '80 and up Diplomat? Will they fit on the knuckles? I assume that the issue is with where the hose connection is on the caliper, and that the location changed in 1980?
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545331
12/14/13 07:30 PM
12/14/13 07:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The slider caliper doesn't care what year the knuckle is .
as long as it is a slider caliper knuckle .
Re: B-body disk conversion question- brake hoses [Re: David_Trimble] #1545332
12/14/13 07:54 PM
12/14/13 07:54 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you run the caliper facing the front, it will contact your pre '70 sway bar.
The best combination is '80 and newer Diplomat calipers mounted facing the rear with '69 Camaro hoses.
Re: B-body disk conversion question- brake hoses [Re: DoctorDiff] #1545333
12/14/13 08:32 PM
12/14/13 08:32 PM
a12rag Offline
a12rag  Offline
Cass . . . why do you say not to use the rear slider caliper ??? I used a 77 F body spindle and slider caliper on my Sport Satellite, and the stainless steel hoses from you . . . only issue I saw, was having to have a "loop" in the hose, the loop can be closer to the caliper or to the body, depending on how you install. I choose to put the loop near the caliper . . . checked for clearance, turning steering lock to lock, and looking at suspension, up and down . . . hoses don't get close to anything . . . after 5000 miles, everthing is still good, and it stops great . . . I know I should post some pics . . . . just my two cents worth . . .
PS - aren't all the slider calipers from 76 up, the same ???? single piston . . .
Mark
