P0514 MIL code....07 3500 Ram 5.9 Cummins
#1545255
12/08/13 04:18 PM
12/08/13 04:18 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
MIL was on this morning....-12*C.....block heater was plugged in for 4 hours prior to starting. Got trouble code P0514...."Battery Temp sensor Performance/Rationality." Read on a another forum that this code appears quite frequently when plugging the truck in overnight. Anyone on here ever had this scenario.....and what was done to eliminate the problem??? Flash???....
Re: P0514 MIL code....07 3500 Ram 5.9 Cummins
[Re: superwrench]
#1545256
12/08/13 05:29 PM
12/08/13 05:29 PM
Posts: 8,164 Plymouth, MI
Blusmbl
Plymouth, MI
Check with the dealer to see if there is a new calibration available for your truck. There isn't anything wrong, the diagnostic is most likely just flipping out when coolant temperature doesn't match the battery temperature after a few hours with the engine off.
