Re: Flickering Oil Light on 98 Jeep
[Re: Powerflow]
#1544063
12/15/13 06:42 PM
12/15/13 06:42 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Like you said, add an external gauge to check against the dash gauge. If oil pressure was zero, the valves should be clattering.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Powerflow]
#1544067
12/17/13 01:49 AM
12/17/13 01:49 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
My '97 Grand Cherokee (5.2) did this exact same thing after the quick lube did an oil change for me. At idle when warm the gauge dropped to nothing but just off idle I had plenty of pressure. Turns out they used 5w30 but the owner's manual says 10w30. I made them change it out and it's been fine ever since. You wouldn't think that minimal difference would matter but it did on mine. Worth a try since you mentioned a recent oil change.
Cheeto It's not perfect. It's not correct. It's not yours!
