Re: Longer Duration Cam with Exhaust Manifolds?
[Re: R/T1968R/T]
#1543860
12/04/13 10:38 PM
12/04/13 10:38 PM
Posts: 4,319 Prospect, PA
BSB67
Prospect, PA
If it is a solid lifter cam, tighten the lash. Back the cam up to "straight up" (ICL=LSA) or 2° retarded. Depending on where you are at with these now, this might get you close.
What cam is it? MP .528? What is the advertised duration, and LSA?
What size engine?
[Re: R/T1968R/T]
#1543861
12/04/13 11:05 PM
12/04/13 11:05 PM
RapidRobert
I'm assuming you are wanting to lower your octane requirement? A longer duration cam would lower your cranking compression number but would reduce driveability as you would lose bottom end power but first (it'd be easier/cheaper) I'd get a multiple keyway timing chain set & retard it 4 deg & see what develops. As you know recheck valve to piston clearance when advancing/retarding as either the intakes or the exhausts gets closer & the other gets farther away. Not sure which would be more effective on what you are after either a longer duration cam or retarding your current cam cuz I ain't a cam guy but just me I'd retard your current one first. Holler how it turns out
[Re: ademon]
#1543867
12/06/13 06:35 PM
12/06/13 06:35 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I am also running 200 PSI cranking.. typically 93 octane Shell and I am good to go.. Stock Iron manifolds. I realize that 93 octane is not available everywhere. there are other ways to knock down octane requirements, including, lower temp thermostat, fuel mixture, and spark timing events, gearing etc....to try, before you tear into the engine..
[Re: R/T1968R/T]
#1543868
12/07/13 11:01 PM
12/07/13 11:01 PM
Posts: 39 mi
ERAT340
mi
