Re: aluminum block on the street?
[Re: mickm]
#1543841
12/05/13 06:54 PM
12/05/13 06:54 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
so what are the advantages/disadvantages to aluminum blocks other than weight. and the cool factor?
Advantages...lighter weight, can be repaired if damaged, can be resleeved.
Disadvantage...higher initial cost. Supposedly an aluminum block won't make as much power due to cylinder instability and heat dissipation, but that depends on who you talk to.
[Re: fullmetaljacket]
#1543843
12/05/13 09:53 PM
12/05/13 09:53 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Especially if you are a true 9 second street car. Good combo you have there to be in the single digits and cruise the streets.
My pump gas 9 second(high 9s at the track, corked up on pump gas, motor only) 3450 Lb Duster had a old cast iron 400 block with four ductile iron sleeves in it and the deck brazed up, it always leaked down good and made plenty of power I have always heard, and shared, that if your running a N/A motor and want the best performance and have a choice, like in NHRA Pro Stock, use a Compact Graphite Iron block, if those are not availble ( especially for all us poor Mopar racers and engine builders) use a plain old cast grey iron block
