Re: Rod bearing pic
[Re: Clanton]
#1543729
12/04/13 05:50 PM
12/04/13 05:50 PM
Posts: 7,506 Az
Crizila
Az
My guess is accelerated wear due to poor journal finish. You got others that look like that?
Fastest 300
Re: Rod bearing pic
[Re: Clanton]
#1543730
12/04/13 06:15 PM
12/04/13 06:15 PM
Posts: 2,091 Delray beach, Florida
Performance Only
any chance you could take a picture with better lighting and also a picture of the back of the bearing shells? From what I see it doesn't look good, that's for sure.
machine shop owner and engine builder
Re: Rod bearing pic
[Re: Crizila]
#1543731
12/04/13 06:53 PM
12/04/13 06:53 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
The oil had some carbon in it from a rich tune so that may be the finish issue you think you see.Or maybe not but the crank was fresh from Moldex.The back of the bearings show no sign of knock.[like new] ps:I made about 40 passes on this engine.
Re: Rod bearing pic
[Re: Clanton]
#1543732
12/04/13 07:02 PM
12/04/13 07:02 PM
Performance Only
A better picture would sure help, even if it had carbon in the oil. It looks like you have an uneven wear pattern that goes all the way to the parting line. Or maybe it's just that the pic is so dark I can't really tell.
Re: Rod bearing pic
[Re: Performance Only]
#1543733
12/04/13 07:11 PM
12/04/13 07:11 PM
Clanton
northern,Ohio,USA
I will work on a better pic.I wonder if the pattern is from the rod walking back/forth on the crank..003 clearence,.025 side,15/40 oil,hv pump,80 psi.
Re: Rod bearing pic
[Re: Clanton]
#1543734
12/04/13 07:15 PM
12/04/13 07:15 PM
Posts: 7,506 Az
Crizila
Az
Actually, that's a pretty good pic. Polish the crank, fresh bearings, and party down. Again, do the other bearings look like that?
Fastest 300
Re: Rod bearing pic
[Re: Clanton]
#1543736
12/04/13 10:29 PM
12/04/13 10:29 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I like to take a ball bearing and a 0-1 micrometer and measure the upper bearing shell. You can measure the crush and tell if it had detonation. Anything more then a couple tenths (.0002) and the tune up is too close to the edge. If it measures the same as the bottom 1/2 just wipe those off with a wore out green pad and reuse them I don't really like .003 for clearance. I'd want .002 but I'm no expert.
Re: Rod bearing pic
[Re: jamesc]
#1543740
12/05/13 11:55 AM
12/05/13 11:55 AM
Clanton
northern,Ohio,USA
i'd want to know why that cap insert is worn on one side.
I posted the pic to find that out if I can.I can not measure the crank with the engine in the car very easy but all rods & bearings were measured with a good bore gauge to begin with.
Re: Rod bearing pic
[Re: Crizila]
#1543742
12/05/13 12:27 PM
12/05/13 12:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wont say anything till I see the others... but the one edge looks like it doesnt have the radius for the crank or enough radius for it
Re: Rod bearing pic
#1543743
12/05/13 12:45 PM
12/05/13 12:45 PM
BradH
And that's the only comment I feel qualified to make on this subject.
I've run lesser powered engines far longer and the bearings from those engines -- while not ideal -- came out with much more consistent wear characteristics.
Re: Rod bearing pic
[Re: Clanton]
#1543747
12/05/13 01:27 PM
12/05/13 01:27 PM
MR_P_BODY
The radius on the bearings were turned down to clear the crank.[SLP-8-7135ch .010] I will try to do 2 more rods on another crank throw.
Did you verify that they clear the fillet... put a slight side pressure on the rod and use a feeler gauge between the crank and rod... I had to cut the bearings on a couple of my engines and at first I thought I had it till I checked it with the feeler gauge and had to go back and add more
Re: Rod bearing pic
[Re: B G Racing]
#1543748
12/05/13 01:28 PM
12/05/13 01:28 PM
Clanton
northern,Ohio,USA
Typical of an engine that is constantly being loaded and unloaded by RPM and torque loads and compression pressure in the cylinders.We see this on our blower engine frequently.Sometimes the rods will kick to the crank and also show radius marking.
Thank you!I did not think I was the only 1 seeing this.
Re: Rod bearing pic
[Re: MR_P_BODY]
#1543749
12/05/13 01:36 PM
12/05/13 01:36 PM
Clanton
northern,Ohio,USA
What is the feeler gauge for,to space the rod evenly?When I put the engine together I did check to see if the rod was stickey when moved to the radius.
Re: Rod bearing pic
[Re: Clanton]
#1543757
12/05/13 05:12 PM
12/05/13 05:12 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Typical,don't idle the engine too low.
The idle is 1100+ and 1k in gear.
You like to hear that rump,rump
