How do you grease the wheel bearings on an 86 4x4?
#1543294
12/03/13 07:11 PM
12/03/13 07:11 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Hey guys, taking my 86 Ramcharger in soon for an oil change, and lube.
I would like to have them grease the front D44 bearing while its on the rack.
Is this done the same was as on the old full time trucks with an access hole in the face of the rotor that lines up with a zerk?
Or is there another trick to getting to these?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: How do you grease the wheel bearings on an 86 4x4?
[Re: hp383]
#1543295
12/03/13 07:50 PM
12/03/13 07:50 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
not like the early trucks.. same procedure as replacing the rotor. Total removeal of the hub/rotor assy..
I am truckless..
[Re: 340SHORTY]
#1543296
12/03/13 08:21 PM
12/03/13 08:21 PM
hp383
State of Confusion
Well that was a huge step backwards in design.
Wonder why they did that?
[Re: hp383]
#1543297
12/03/13 08:37 PM
12/03/13 08:37 PM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Wow, I never knew that. Yeah, after having a newer one apart you gotta tear it down. Or drill the hub for an angled zerk.
