Page 1 of 3 1 2 3
Time to Paint the D100. #1543235
12/03/13 06:19 PM
12/03/13 06:19 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Decided it was time for paint on the D100. I do like the patina look. But after 3 years it was starting to looks a little worse, so I decided to preserve it with new paint. Going with the same original two-tone paint scheme.
Re: Time to Paint the D100. [Re: jstollfu] #1543236
12/03/13 06:20 PM
12/03/13 06:20 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Started with the inside of the box since it was in the worst shape.
Re: Time to Paint the D100. [Re: jstollfu] #1543237
12/03/13 06:21 PM
12/03/13 06:21 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Box was pretty crusty. It was used as a "truck" at one point in it's life.
Re: Time to Paint the D100. [Re: jstollfu] #1543238
12/03/13 06:23 PM
12/03/13 06:23 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Bottom of the tail gate had some rust through.
Re: Time to Paint the D100. [Re: jstollfu] #1543239
12/03/13 06:24 PM
12/03/13 06:24 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Inside of the box stripped.
Re: Time to Paint the D100. [Re: jstollfu] #1543240
12/03/13 06:26 PM
12/03/13 06:26 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Welded up the rust on the bottom of the tail gate. (Should have just found a better tail gate).
Re: Time to Paint the D100. [Re: jstollfu] #1543241
12/03/13 06:27 PM
12/03/13 06:27 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Next up is to knock the dents out of the wheel wells.
Re: Time to Paint the D100. [Re: jstollfu] #1543242
12/03/13 06:30 PM
12/03/13 06:30 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Finally I get to ditch the tri-pod mount mirrors and install the pedestal mirrors.
Re: Time to Paint the D100. [Re: jstollfu] #1543243
12/03/13 06:32 PM
12/03/13 06:32 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
More soon.
Re: Time to Paint the D100. [Re: jstollfu] #1543244
12/03/13 07:23 PM
12/03/13 07:23 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
1981 Dodge D150 360 auto
Re: Time to Paint the D100. [Re: basketcase] #1543245
12/03/13 07:27 PM
12/03/13 07:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
JB Rhinehart, Realist
A-Body's RULE!
Re: Time to Paint the D100. [Re: Rhinodart] #1543246
12/03/13 07:46 PM
12/03/13 07:46 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Time to Paint the D100. [Re: jstollfu] #1543247
12/03/13 08:12 PM
12/03/13 08:12 PM
Az
HOT IN AZ Offline
HOT IN AZ  Offline
Az
You didn't even need to paint it, just removing those mirrors made the truck!
Re: Time to Paint the D100. [Re: HOT IN AZ] #1543248
12/03/13 08:21 PM
12/03/13 08:21 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have a similar two-tone paint on my '86 Ramcharger, no side mirrors and a lot more to do before I can think about paint
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Time to Paint the D100. [Re: HOT IN AZ] #1543249
12/04/13 12:47 AM
12/04/13 12:47 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Wow! You have been busy, jstollfu! What did you use to get your bed stripped so clean?
Nice work
Re: Time to Paint the D100. [Re: 77ProStreet] #1543250
12/04/13 01:48 PM
12/04/13 01:48 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
In retrospect I should have removed the bed completely and had it sand blasted. But unfortunatly, I have no way to transport the bed except on the frame of the truck. So I used 2 inch bristle discs to strip the ribs on the sides of the bed. Then I used a couple of wire brush cups on a grinder to strip the loose rust off the bed floor. Then I put 4-5 coats of Navel Jelly rust remover on the floor to get the deep down embeded rust off. That Navel Jelly really works, it has to sit for hours, not mins and takes a few coats but it cleaned up the bed floor fairly well.
Re: Time to Paint the D100. [Re: jstollfu] #1543251
12/05/13 07:00 AM
12/05/13 07:00 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
It looks really good. I'm in the same boat as you, should get it blasted but no way to get it there. But its one of the last things on my list.
Re: Time to Paint the D100. [Re: 77ProStreet] #1543252
12/05/13 09:38 AM
12/05/13 09:38 AM
cleveland, tx
dodgzilla 1 Offline
dodgzilla 1  Offline
cleveland, tx
my 74 extended cab that i had was painted the exactly like your truck. it is looking good. i have a clean shaved tail gate with a flip kit that would look good on there.
Re: Time to Paint the D100. [Re: dodgzilla 1] #1543253
12/06/13 12:26 PM
12/06/13 12:26 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
I had a smoothed tail gate with the handle flip, and a rear roll pan on my 84 d150. I liked the look. However, this one is going to stay stock in appearance. Same two tone colors, as ugly as the colors are they have grown on me. All the stock trim stays. Hopefully I can get out in the garage this weekend, I feel like I sold my soul to the paint store yesterday for supplies.
Re: Time to Paint the D100. [Re: jstollfu] #1543254
12/06/13 04:20 PM
12/06/13 04:20 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Seeing that you live in Michigan, how do you heat your garage? I live in the "wet side" of Washington state and while today's temp will be mid 30s, my attached garage is not heated by itself. So the question remains, how do you heat your garage area so that you can work comfortably and safely?
2008 Honda Element
Page 1 of 3 1 2 3
