Bought a 99 durango. Can you help diagnose issues?
#1542439
12/01/13 08:28 PM
12/01/13 08:28 PM
Posts: 680 NW IL
Biggie
NW IL
Bought this 99 durango 4x4 with the 5.2l motor. It currently has 113k miles on it. When we test drove it, it had a sputter or almost like a miss. After it warmed up it ran fine. On our 74 mile trip home things changed. Every time I left a stop it seemed like the engine was cutting out. After about 20 mile we pulled over and let it sit for a bit. When we went to leave it ran awesome. Not a problem. I stopped to get gas 30 miles later and as we were leaving the gas station it seemed to cut out again, and did so a couple times the rest of the trip. The previous owner had a stack of records from the day he bought it. He has stuck alot of money chasing this issue. New cap and rotor, distributor, plugs, wires, pcm, tb sensor, crank sensor, iac, ect. His records showed he has had it towed on many occasions which resulted in parts thrown at it. Is there any one that can give me suggestions? Thanks Eric
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon 03 chrysler 300m 10 dodge charger
Re: Bought a 99 durango. Can you help diagnose issues?
[Re: Biggie]
#1542440
12/01/13 08:34 PM
12/01/13 08:34 PM
Posts: 905 SD
zrxkawboy
SD
I would test fuel pressure.
Edit: No stored codes?
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1542441
12/01/13 08:43 PM
12/01/13 08:43 PM
Posts: 680 NW IL
Biggie
NW IL
I tried the the key on/off trick and it didnt work. Im going to see if I can borrow a code reader tomorrow. When we left it had no check engine light on. About half way home the engine light came on.
I can see if I can check fuel pressure but if its intermittent it would only show up when its having issues right?
[Re: Biggie]
#1542442
12/01/13 08:49 PM
12/01/13 08:49 PM
Posts: 905 SD
zrxkawboy
SD
Definitely find out what the code is. Many parts stores will read codes for free.
See what the code is and go from there, but it may still be worthwhile to check fuel pressure. It might not show anything until the problem is happening, like you said, but if it were just a little bit low, that might show up as an intermittent problem.
[Re: zrxkawboy]
#1542443
12/01/13 09:47 PM
12/01/13 09:47 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Could be the intake belly pan, mine finally sucked in and caused all kinds of havoc. Easy enough to check too.
"I think its got a hemi"
[Re: savoy64]
#1542445
12/01/13 10:48 PM
12/01/13 10:48 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Does it seem like it's running rich when it sputters? I have found the wiring at the temperature sensor, down by the thermostat housing, cracked and peeling away. When this shorts the two wires together the computor thinks the engine temp is like 40 degrees below 0. This causes a very rich condition that gets progressively worse. Also if the thermostat is sticking open the adaptive memory throws more fuel at it because it's too cold for too long. Over time this also creates an overly rich condition.
[Re: poorboy]
#1542447
12/02/13 02:17 AM
12/02/13 02:17 AM
Posts: 680 NW IL
Biggie
NW IL
List of replaced parts/service from previous owner
1.trans filter, gasket, fluid 2.battery 3.dist cap, rotor, wiper arm 4.wire harness to pcn, right fog lamp 5.a/c compressor work 6.wire harness from pdc to fuel pump 7.pdc control center assy and wire harness 8.idol air control motor, striker assy for hood, two regulators and window switch, tb cleaning, t-stat, gasket and coolant 9.fuel pump assy, module fu(?) central timer module 10.battery 11.plugs, wires, cap, rotor, anti lock brake sensor, wheel speed sensor, gear case cover, drive pinion seal, left and right back wheel cyl, right rear window reg, intake man gask 12. muffler, tailpipe, and clamp 13 throttle pos sensor 14.spark plugs, cleaned combustion chamber, ignition second cable, dist cap and rotor 15. battery, alignment serv, inner tie rods left and right
Each number represents what was all done on each visit. No particular order. Total of $14,734! all done at dealerships.
[Re: Grizzly]
#1542450
12/02/13 01:54 PM
12/02/13 01:54 PM
Posts: 680 NW IL
Biggie
NW IL
The prev owner has chased this problem for atleast 50k miles. If it was water wouldnt it work itself out by now? Also they replaced the fuel pump so I imagine they would have cleaned the tank out?
We went to check the code and my uncle accidently cleared the code. Im going to have to drive it but first need plates and insurance.
My uncle told me he had a friend that had a durango that was doing the same thing and it ended up being the coil. Dont think that has been replaced yet lol
[Re: Biggie]
#1542452
12/02/13 02:06 PM
12/02/13 02:06 PM
gdonovan
Oakdale CT
Eliminate the intake, its a 30 second check.
block off the PCV port and see if the breather is pulling a vacuum.
[Re: superwrench]
#1542453
12/03/13 09:10 PM
12/03/13 09:10 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Two things come to mind......those vehicles had EGR issues, and rough run/hesitation was a symptom....and a worn intermediate gear/distributor shaft bushing in the block will cause random misfire. I mean....what the heck!!!...with the list of stuff thrown at the vehicle, might as well try those.
"those vehicles" don't even HAVE an EGR...
none of the gen 3 Dakotas or Durangos have EGR.
Could be the coil.
I would also check the O2 sensors, but those shouldn't come into effect on engine start up because it's running in open loop and doesn't read the sensors until after it's up and running.
Check the valley pan gasket as well, although I can say that your symptoms do not sound like it's the pan gasket. but it's a quick check. engine off, open the throttle wide open and look down into the plenum. if you see oil pooling in the bottom, then the plenum/pan gasket is shot.
**Photobucket sucks**
[Re: 70Cuda383]
#1542454
12/03/13 10:31 PM
12/03/13 10:31 PM
Posts: 680 NW IL
Biggie
NW IL
It starts up with no problem. I plan on changing the coil tomorrow. I will also check the plenum gasket while Im at it. Thanks for the replies so far.
[Re: Grizzly]
#1542456
12/03/13 11:58 PM
12/03/13 11:58 PM
Posts: 680 NW IL
Biggie
NW IL
sure will just have to wait for it to go off again lol. I should be getting plates and insurance on it tomorrow and will drive it then. Unfortunately I wont drive it much till next week. Going on a mini vacation thursday.
[Re: Biggie]
#1542457
12/04/13 08:39 AM
12/04/13 08:39 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Dont rule out the O2s.We had a Jeep and Dodge truck that would pretty much do the same.Even in open loop they did it.O2s never threw a code but with a scanner while driving you could watch them whack out.Yeah they arent supposed to affect anything in open loop but they did.Find someone with a scanner and watch the live data.Rocky
Chrysler Firepower
[Re: therocks]
#1542458
12/04/13 06:07 PM
12/04/13 06:07 PM
Posts: 680 NW IL
Biggie
NW IL
I got plates and insurance on it today. I put a new coil on because it was cheap and easy. Drove it for about 15 miles and the check engine light came back on. The code is po132 which is the bank 1 o2 sensor. I might replace the catalytic converter along with the sensor just to rule it out. Plus it looks like most of the exhaust is fairly new except the cat.
