727 question #1542299
12/01/13 02:49 PM
12/01/13 02:49 PM
North Florida
RebelDart Offline OP
super street
super street
North Florida
Was going to replace a leaky pan - question about the stainless ball - assuming it's a part of a valve assembly, somewhere. I haven't driven the car further than around the block (restoring)also debris caught by filter appears to be gasket material - analysis/ suggestions ?
Re: 727 question [Re: RebelDart] #1542300
12/01/13 02:49 PM
12/01/13 02:49 PM
North Florida
super street
super street
North Florida
pic 2
Re: 727 question [Re: RebelDart] #1542301
12/01/13 02:50 PM
12/01/13 02:50 PM
North Florida
super street
super street
North Florida
pic 3
Re: 727 question [Re: RebelDart] #1542302
12/01/13 02:52 PM
12/01/13 02:52 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
There are a number of check balls in the valve body but near impossible for them to fall out without the valve body coming apart if they were all installed in their proper locations. Possibly a bearing ball from the output shaft bearing if it came apart now or at some time in the past?
Re: 727 question [Re: RebelDart] #1542303
12/01/13 03:01 PM
12/01/13 03:01 PM
If you have the pan back on/it filled up I'd drive it & see how it acts. If you are still undone like the pic(s) show you could pull/seperate the valve body & see if all the check balls are present. My Q would be who had the valve body open last or who rebuilt the trans
Re: 727 question [Re: PC-CHARGER] #1542304
12/01/13 03:01 PM
12/01/13 03:01 PM
North Florida
super street
super street
North Florida
I'll check the bearing as best I can - this ball has at least two flat spots on it - I have not seen what the balls in the valve body look like as this is a first for me ..... would they be (or should they be)perfectly smooth ball bearing or do they show hard use ? I'll take a close up in a second. If they should be smooth then this definitely has hard wear - more like tailshaft bearing as you suggest ....
Re: 727 question [Re: RebelDart] #1542305
12/01/13 03:06 PM
12/01/13 03:06 PM
Yeah I was wondering about that flat spot myself. The ones in the VB would be round. wondering if it was a loose extra one that got crushed a bit during assembly but I think that would have caused a noticeable problem during the assembly process
Re: 727 question [Re: RebelDart] #1542306
12/01/13 03:08 PM
12/01/13 03:08 PM
North Florida
super street
super street
North Florida
This "bearing" definitely had issues at some point - can't imagine it could have gotten in this kind of condition serving as a check valve, definitely serious/hard wear - prolly as you suggested - output shaft bearing from previous "issues" as this tranny was recently rebuilt ...........
Re: 727 question [Re: RebelDart] #1542307
12/01/13 03:09 PM
12/01/13 03:09 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As was posted, the check balls in the VB are perfectly round.
Re: 727 question [Re: PC-CHARGER] #1542308
12/01/13 03:11 PM
12/01/13 03:11 PM
when you get to it post what you see in the output shaft bearing
Re: 727 question [Re: RapidRobert] #1542309
12/01/13 03:18 PM
12/01/13 03:18 PM
North Florida
super street
super street
North Florida
Still in virgin territory - I have play in the output shaft (tail side) so I may have opened up a can o' worms. What's involved in replacing the bearing or I'm I best off to drop it off at a shop ? Can I get a confirmed visual diagnoses or no (removing the seal now) ..... thanks guys
Re: 727 question [Re: RebelDart] #1542310
12/01/13 03:30 PM
12/01/13 03:30 PM
North Florida
super street
super street
North Florida
This bearing appears too small for input/output shaft ball bearing _ measures like 7/32 ?
Re: 727 question [Re: RebelDart] #1542311
12/01/13 03:35 PM
12/01/13 03:35 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
I have seen many ball bearings that have crashed in electric motors and I have never seen one loose a ball without tearing the cage to pieces. Usually they lock the motor up or spin the race in the housing damaging the fit. The only other ball it might be is the detent shift position ball but you would have trouble shift if that is the case in my opinion.
I have a 518 valve body apart right now so if you need any sizes shoot me a PM
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: 727 question [Re: RebelDart] #1542312
12/01/13 08:25 PM
12/01/13 08:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was going to say it is way too small for a rear support bearing , it is more the size of the detent ball for the shift lever.
Re: 727 question [Re: RebelDart] #1542313
12/01/13 09:06 PM
12/01/13 09:06 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
I just measured the detent ball from my valve body and it is .343
Re: 727 question [Re: RebelDart] #1542314
12/01/13 09:24 PM
12/01/13 09:24 PM
North Florida
super street
super street
North Florida
Just borrowed a caliper - around .210, sure this isn't from any carrier bearing - where's the detent bearing/ball located ?
Re: 727 question [Re: RebelDart] #1542315
12/01/13 09:39 PM
12/01/13 09:39 PM
In the side of the valve body, held in by the rooster comb
Re: 727 question [Re: RebelDart] #1542316
12/01/13 09:57 PM
12/01/13 09:57 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
The detent ball is located on top of the valve body on the shaft that the gear selector hooks on to it along with the spring it sets the valve body in the correct gear position. But your saying the one you have is just under a 1/4" so unless someone has been in there and lost the original I would guess now that it has come from somewhere else.
Re: 727 question [Re: OldMoparMan] #1542317
12/01/13 10:04 PM
12/01/13 10:04 PM
North Florida
super street
super street
North Florida
I'm gonna have to check this out further this week - I have a really sloppy shifter - hard to find a sweet spot in Park for ignition to work, very slight detent feel when going between positions. Maybe this is the detent ball ? Would'nt/couldn't the ball get really worn/deformed over years ? Could it have come and made it's way to the pan ?
Re: 727 question [Re: RebelDart] #1542318
12/01/13 10:09 PM
12/01/13 10:09 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
OK that sounds like the detent ball so you will have to drop the valve body to check it out, here is a crude pic.
