Re: Noticeable Drivetrain Shake at Idle
[Re: MuuMuu101]
#1542136
12/01/13 11:52 AM
12/01/13 11:52 AM
RapidRobert
It ain't from that (low comp in 1cyl). There is something else going on that's affecting multiple cylinders. Get down there & do a quick visual to eliminate the mtr mounts. check rotor phasing, blast out the 2 carb mixture screw holes with brake kleen, check the plugs & wires. Spray for vac leaks. EDIT Is that a solid lifter 273? Not sure if the lash was way off if that would do it otherwise if so I'd think it would of showed up on the compression test. Maybe someone can chime in if that is a potential
[Re: elmor353]
#1542138
12/01/13 07:38 PM
12/01/13 07:38 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I had the same problem with the 440 in my truck. Didn't seem to notice when driving it, but at an idle, it shook pretty bad. Had a burnt exhaust valve and no compression in one cylinder. What were the rest of your cylinders running for compression? Normally you don't want to run more than 10 percent difference.
I believe he said the others were running somewhere around 120-130 psi. I'm not too sure. Honestly, I don't know too much about engines or how to troubleshoot them, but I'll be done with my next school quarter in 2 weeks and may have some time to fiddle around with it during my Christmas break.
[Re: JohnRR]
#1542141
12/01/13 09:32 PM
12/01/13 09:32 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
What ignition system on the engine? This is not a drivetrain vibration if it is happening when stopped and at idle, this is an engine vibration.
It's electronic. Someone swapped out the standard points system.
[Re: 340SHORTY]
#1542142
12/01/13 09:33 PM
12/01/13 09:33 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
maybe you have lumps in your gas..
What do you mean by this? I do fill it up with 91 octane (highest I can get over here).
[Re: MuuMuu101]
#1542143
12/01/13 10:07 PM
12/01/13 10:07 PM
RapidRobert
I'd start on a few things & see if I could pin it to either fuel (carb/vac leak) or ign (plugs/wires/reluctor gap/rotor phasing)
[Re: MuuMuu101]
#1542145
12/02/13 02:34 AM
12/02/13 02:34 AM
Posts: 75,087 A Banana Republic near you.
JohnRR
Why are you wasting money running 91 in that engine ?
[Re: JohnRR]
#1542146
12/02/13 02:52 AM
12/02/13 02:52 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I wasn't sure what the recommended octane was. Most people I heard run 91. I just didn't want to develop an engine knock. What do you recommend?
[Re: Dcuda69]
#1542149
12/03/13 12:02 PM
12/03/13 12:02 PM
Posts: 5,166 CT
GTX MATT
CT
I worked on a buddies 383 last year that had a dead cylinder from a burnt valve, it idled rougher than it should have but it didn't shake violently.
Is it worse in gear, even if you bring the revs up to the same as idle in park? Sounds like a busted motor or tranny mount to me.
[Re: JohnRR]
#1542150
12/03/13 01:53 PM
12/03/13 01:53 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
What's the rated compression ratio ?
Edit ... mymopar.com says rated at 8.8 so it's closer to 8.0 , you should be able to run it on 87 ...
Thanks!
[Re: GTX MATT]
#1542151
12/03/13 01:55 PM
12/03/13 01:55 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It's no better or worse whether it's sitting in Park in the garage or in Drive at a red light. I'm not sure if my center console is bolted down completely, but once it starts going, you can hear and see it rattle and vibrate. It also doesn't seem to happen all the time while driving (either that or I'm not noticing it).
