overheating 02 Ram 1500 #1540795
11/27/13 09:43 PM
11/27/13 09:43 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Just running this past any of you truck owners. I've got a 02 1500 with the 4.7 and it gets hot pretty quick. It has a new thermostat. It gets hot enough to puck out the tank. The owner thinks it may be the water pump. I think it's just the radiator. Any opinions would help.
Re: overheating 02 Ram 1500 [Re: fastmark] #1540796
11/27/13 09:56 PM
11/27/13 09:56 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Electric fan coming on?I replaced 4 fan clutches on an 07,would start to overheat under load. May have already blown a headgasket,does not take much overheating to blow one on a 4.7.
Re: overheating 02 Ram 1500 [Re: Geezer] #1540797
11/27/13 11:50 PM
11/27/13 11:50 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This one does not have an electric fan. It has a regular clutch and fan direct drive from the motor. I checked the oil and it did not have signs of water so I hope we don't have a head gasket problem.
Re: overheating 02 Ram 1500 [Re: fastmark] #1540798
11/27/13 11:59 PM
11/27/13 11:59 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I bet you're right. 11 years of dust is settled in the fins. Pressure washer and flush the fins until you see clear water coming out of it.
Mo' Farts
Moderated by "tbagger".
Re: overheating 02 Ram 1500 [Re: Grizzly] #1540799
11/28/13 04:04 AM
11/28/13 04:04 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
If its the radiator one side will be noticeably colder than the other side. If a 4.7L is overheated it can warp the cylinder head enough that the gasket loses it's seal. There's a spot in the deck surface where the coolant passage is close to the bore and that's where it usually leaks when hot. So if you have the heads off make sure they are checked for flatness...
