High HP, heavy car,wheelstands-best tire???
#1540569
11/27/13 04:25 PM
11/27/13 04:25 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Hands down Goodyear tires work the BEST on my car(31.014.0/15)but they go away after 30 or so passes. Yes I am running tubes,tire screws,running enough pressure(12 lbs.),have wheelie bars,and I rotate every time or two at the track. My car is heavy(3600)with a brake and low 1.30's are the norm until they go away.Then they become unpredictable spinning and going one direction or the other. Put new ones on and all is well again!!! I race practically every weekend during the summer and I don't want to go broke again this year. Does anyone else have good luck with other brands (longevity) with their HEAVY wheel standers? Car is a 70 B body mini tubbed with 572 wedge. Thanks Mike
Re: High HP, heavy car,wheelstands-best tire???
[Re: racerx]
#1540574
11/27/13 06:33 PM
11/27/13 06:33 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Sorry op. not trying to jack,but i have a ? is there a visual way of determining if side walls or going/gone away?
Many times you can let the air out and actually feel the seperation of plys in the side wall.
[Re: racerx]
#1540575
11/27/13 06:49 PM
11/27/13 06:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Like Bob (BG Racing) said, but the biggest/easiest way is to check the runs and when the 60' starts dropping the walls are going away.. I can tell you how many runs are on my tires based on the 60'... at 1.23 I need new tires(starts at 1.19 60')
[Re: 1967dartgt]
#1540578
11/27/13 08:41 PM
11/27/13 08:41 PM
MR_P_BODY
Now do you get more runs out of your tires at a lighter weight?
I get about 80 runs on a set then I sell them... I hit them pretty hard... just the standard side wall but with tubes... I replace the tubes with every 2 sets of tires... if I run a lot of 10.0 stuff then I can double the number of runs or even up to three times the runs(depending on how many runs are at WOT on the launches with the 10.0 stuff)
[Re: 70satelliteguy]
#1540579
11/28/13 03:36 PM
11/28/13 03:36 PM
Posts: 2,917 A shed in England
Tig
A shed in England
Ours last around the same (29.5 x 10.5) 30 ish passes and the 60fts drop off. The car becomes inconsistent and feels loose/floaty through the top end. We tried stiff sidewalls but the car just didn't seem to like them A friend of ours tried out a pair of old ones we were throwing away despite my insistence they would be no good, one pass was all he made! I guess it's the price you pay for a heavy car and hi HP. Caltracs seem to hit the tyre hard too. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: pittsburghracer]
#1540581
11/28/13 04:24 PM
11/28/13 04:24 PM
Posts: 2,151 Fancy Farm Ky
wyoming
Fancy Farm Ky
You make more steam than me, and different size tire to boot, but we are close on weight 3740 here, and wheels up, but I have good luck with MT stiffwalls with tubes, screws, I run 31/10.5W/15, Ive run all brands and have better longivity with MT and Phoenix than the others, dont know if that applies to your car much, but have you tried the MT?
[Re: montessa]
#1540583
11/28/13 08:07 PM
11/28/13 08:07 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"I guess it's the price you pay for a heavy car and hi HP. " I am beginning to realize this!!! Suspension is ladder bars. Car runs best of 9.40's on motor and high 8's on juice. Guess I should be happy I am not trying to keep tires on a pro stock or a fuel car! Thanks Mike
#1540584
11/28/13 09:40 PM
11/28/13 09:40 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Not as fast (down into 9.80s) and not as heavy (3200) but hitting the tires pretty hard with the stick. Have 180 passes on these w/best 60' at the end of this year 1.34. Twisted an axle and an axle tube with these when I had caltracs, much smoother w/the ladder bars 29.5 x 10.5S Am happy with them
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#1540585
11/29/13 12:50 PM
11/29/13 12:50 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I have MT 1074S 14X32`s on mine. They work well on my stick car as well The tires are 21yrs old tho. But to answer the question : I have REALLY punished these tires. Learning the hard way with too much clutch,broken ladder-bar mounts/bent frame connectors/broken ring&pinion/violent wheelstands. Tires were the most predictable part.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
#1540586
11/29/13 01:52 PM
11/29/13 01:52 PM
Posts: 679 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
Thanks for the reply's. I looked up the 29.5 X10.5S MT .It requires a 10.0 in. rim and only has a 10.0 width.The track where I race is not always "great" in track prep.A 10.0 in. tire may be borderline trying to hook up my car most of the time. My rims are 12.0 inches The o.d of 29.5 would also mess with my gear ratio. I am also afraid it might look kinda funny on my car being so small(10.0 in.) . It might work sometimes and not wear out as fast but I don't think it is the tire for me Thanks Mike
We run a 12inch wheel as well. Look at the 31 x 10.5W stiff sidewall too.
Casey
