Factory Ride Height #1540222
11/26/13 06:04 PM
11/26/13 06:04 PM
Harper's Ferry WV
aardakota Offline OP
Harper's Ferry WV
Would anyone have the specs on factory ride height for a '69 Sport Satellite?
Re: Factory Ride Height [Re: aardakota] #1540223
11/26/13 08:03 PM
11/26/13 08:03 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you not have a service manual?
Re: Factory Ride Height [Re: aardakota] #1540224
11/27/13 04:07 AM
11/27/13 04:07 AM
GMP440 Offline
GMP440  Offline
Go on the Hamtramck site. There is a document there that lists front and rear bumper heights from the ground. That should get you very close to what your ride height should be.
Re: Factory Ride Height [Re: GMP440] #1540225
11/27/13 12:03 PM
11/27/13 12:03 PM
Harper's Ferry WV
Harper's Ferry WV
No I unfortunately do not have a manual. Thanks for the advice. i was unaware of the Hamtramck site. will have to check it out.Do you have a link/ip address for it, I'm not finding it. thanks again, mark
Re: Factory Ride Height [Re: aardakota] #1540226
11/27/13 01:11 PM
11/27/13 01:11 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
Here's the link:
http://www.hamtramck-historical.com/PassengerCarBumperHeights-01.shtml
If the link does not work, the list is in the library under articles.
Re: Factory Ride Height [Re: sixpackbird] #1540227
12/01/13 04:32 PM
12/01/13 04:32 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Here's the link:
Thats an interesting set of documents that I've never seen before. Most service manuals will show ride height set as show below with most of our cars set between 1.25" to 1.78" difference. This also takes the engine weight, passenger and liquid load, and tire height out of the equation.
