Tubing Diameter?
#1539172
11/24/13 02:17 PM
11/24/13 02:17 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Getting ready to tie my front cage bars to the front of the vehicle. What size tubing am I suppose to use? It will be Mild Steel.Would you tie to the frame rail or build a pad and keep it inside the fender wheel? thx matt
[img] [/img]
Re: Tubing Diameter?
[Re: B G Racing]
#1539175
11/24/13 03:15 PM
11/24/13 03:15 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Most everybody uses 1 5/8.
I have not been able to find any requirement for these bars in any of the 25 series SFI specs. It really is not part of the roll cage, technically. The reason I have always thought this bar was a great addition is to tie your chassis to you roll cage. It also helps keep the cage in front of you during an accident.
My personal opinion any car that has had the front fender pans removed should have these bars. They should also tie to the shock towers.
Leon
[Re: Leon441]
#1539176
11/24/13 04:23 PM
11/24/13 04:23 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
1-5/8 c.m. on my challenger.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
