Re: Driving a Mopar with a manual Valve Body.. [Re: cal_gecko] #1537975
11/22/13 06:25 AM
11/22/13 06:25 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
A Griner should be a low band apply unless it's an older one.
Realistically, you can start out in 2nd or even 3rd if you want, it really won't hurt anything.
You can tell instantly if it's an LBA or not. Back off of it in 1st. If it has engine braking it's an LBA, if not, it isn't.
Do not downshift into first while you're coasting with an LBA. Try it once and you'll find out why.
As said before do not downshift to low and get on the gas if it's a non LBA. You can roll the sprag and things will go downhill from there. 904 isn't nearly as bad as a 727 about rolling the sprag, but it can still happen. 904 usually won't explode either.
Yes, you can downshift 3rd to 2nd and gas it for passing, etc., LBA or not.
I've driven many thousands of miles on the street with a manual valve body. No big deal once you get used to it. Almost as much fun as a clutch car.
Re: Driving a Mopar with a manual Valve Body.. [Re: slantzilla] #1537976
11/22/13 06:45 AM
11/22/13 06:45 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Here's a reverse manual 727 non LBA question.
I've launched at the track before with my hand on the shifter and right at/after launch it goes into second. (the shift-r-gate doesn't work every time as I expected).
I pushed it back into first (still under full throttle).
Is that a problem?
Is a full throttle downshift into first a no-no with a non lba valve body?
Re: Driving a Mopar with a manual Valve Body.. [Re: SNK-EYZ] #1537977
11/22/13 07:39 AM
11/22/13 07:39 AM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Is that a problem?
IMO that is a No No
You might just have company in the drivers compartment downshifting to first under full throttle with no LBA. Trans tunnel exploding and spraying you right foot with transmission parts.
Perhaps you should fix your shifter!
Ive ran nothing but reverse manual valve body's in all of my auto Mopars, and that is quite a few Mopars!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Driving a Mopar with a manual Valve Body.. [Re: BB65Barracuda] #1537978
11/22/13 08:08 AM
11/22/13 08:08 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Is that a problem?
IMO that is a No No
I guess I won't be downshifting it again.
It's got a trans shield and one of CRT's Ultimate sprags along with other stuff in it.
I need to figure out why the shifter started doing that, it didn't originally.
Several people simply said "Don't put your hand on the shifter til you're ready to shift to 2nd".
I was launching with my hand on the shifter.
Re: Driving a Mopar with a manual Valve Body.. [Re: cal_gecko] #1537979
11/22/13 10:19 AM
11/22/13 10:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I have a Turbo Action but I'm guessing it's the same deal, drive it like you normally would, shift when you want. And yes you can start in 2nd, but I never do, except the burn-out box because YOU HAVE TO. I don't down shift unless I'm going real slow and then I go all the way to 1st because mine will "free wheel" in 1st. I have a reverse pattern, I'd guess standard would be better for all out street use.
Coming soon!!!!
Re: Driving a Mopar with a manual Valve Body.. [Re: dOc !] #1537980
11/22/13 10:55 AM
11/22/13 10:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I must have a stump-puller motor in mine compared to you other .... on a EZ grandma leave at a stop lite ... the BUTTON on my dash shifter is in D .... with a 2.76 gear .
...and none of youz say PICS or it never happened ..
What the heck are you trying to say ?? I think you may be the on this one.
I have been driving my reverse manual valve body mopars since the 70's on the street.
One simple rule is just dont downshift into first until you are at a complete stop. Dont matter if its LBA or not as long as you dont downshift into first until you stop everything will be fine. You can downshift to second at normal speeds just like any auto trans would do. When I am coming to a stop at a redlite I downshift to second about 25 mph and if the lite turns and I have to go I will already be in second but if the lite dont turn then I come to a stop and then downshift to first. And I just upshift like a normal auto would shift unless at the track and I am racing then of course I wind it up some. Its not a big deal if you just use common sense and drive it like a normal car. And as was said the one rule is just dont downshift to first until you stop and you will be fine no matter what valve body is in it. That will protect the overrunning clutch (sprag) in the trans because if it has no LBA and you downshifted to first while moving and get on the gas you can hurt the rollers in the sprag so to be safe just come to a stop before you downshift into first. Downshifting into second and getting on the gas is fine. Ron
Re: Driving a Mopar with a manual Valve Body.. [Re: 383man] #1537981
11/22/13 12:44 PM
11/22/13 12:44 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
Thanks for all the info, guys!! Yes, it's a reverse pattern, and I remember John Cope talking me into the LBA aspect of it.. I think I also got upgraded clutches, kevlar bands and koleans steels, in addition to the low 1st gear set from him ... I had no idea what any of it meant, but it sounded like it was 'necessary' to build a solid trans for the car.
I also put in a 2800rpm stall converter .. so the trans is more high performance than my engine, at this point!
Thanks for the explanations to my rookie questions without making me feel like an imbecile - it was a little embarrassing asking questions about how to drive an automatic transmission!!!
So - Never downshift to 1st unless I'm at a dead stop is rule #1 !!
If doing a burnout, start in 2nd gear is rule #2
Drive it like I stole it is rule # 3
Re: Driving a Mopar with a manual Valve Body.. [Re: dOc !] #1537982
11/22/13 12:51 PM
11/22/13 12:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sorry for stepping on your thread Cal. I get the anticipation. I haven't been out of my ride for as long as you but I am getting antsy.
Sounds like you have a sweet set up. You are going to enjoy it. The wait is almost over. I am sure once you get behind the wheel you will just get the feel for how it works.
and now...
....leaving in THIRD is fine ... just don't get into the secondaries of the carb ...
Sometimes I think you aint all there.
I am there - ALL there ...on my push-button-shifter .. and ferr-surr NOT spaced-out and lost
And not a bit judgmental, well... maybe mental.
Yu sher speel like yer spaced out.
And ralerly if ever have something useful to say.
have a good day glass man. It's all in fun, I hope.
if not too bad fer u
I have mechanical Aptitude.
I can screw up anything.
Re: Driving a Mopar with a manual Valve Body.. [Re: bboogieart] #1537983
11/22/13 04:09 PM
11/22/13 04:09 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
You can downshift to 1st while going if you have a free wheeling first setup just NEVER go back onto the gas pedal. Your using a race only piece in a street application as I and many others do. That's why if you need to pass that Camaro you need Horsepower not a downshift.
Ron
Re: Driving a Mopar with a manual Valve Body.. [Re: RJS] #1537984
11/22/13 04:21 PM
11/22/13 04:21 PM
P
Paul_Fancsali Offline
P
I have had 3 turbo action valve bodies over the years and went back to full auto trans, Too many problems and U joints and cops don't like the chirp squeal shifts . Beside programed correctly full auto valve body's will shift just as fast esp 2-3.
Re: Driving a Mopar with a manual Valve Body.. [Re: Paul_Fancsali] #1537985
11/23/13 11:25 AM
11/23/13 11:25 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
I have raced and street driven mine for some years now. The only issue I had was breaking the front band anchor wedge when I down shifted from too high an RPM.
Garth
Re: Driving a Mopar with a manual Valve Body.. [Re: cal_gecko] #1537986
11/23/13 09:17 PM
11/23/13 09:17 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Kinda like driving that old 74 /6 Dodge van my folks had with the "non-synchro" 3 speed manual. You couldn't put it into 1st unless you were at a stop since 1st gear had no synchro's, only 2nd and 3rd.
There were moments when you rolled up to light and it changed on you when you almost came to a stop, traffic behind you, no time for a complete stop............so off you go in 2nd and with it the shuddering of the dash.
