map light harness 2 #1537339
11/20/13 12:11 PM
11/20/13 12:11 PM
yellow70charger Offline OP
Whats the difference, or what's the extra wiring for on these two map lights harness's? Trying to figure out which one is right for my car thanks James
Re: map light harness 2 [Re: yellow70charger] #1537340
11/20/13 12:13 PM
11/20/13 12:13 PM
other harness
Re: map light harness 2 [Re: yellow70charger] #1537341
11/20/13 08:35 PM
11/20/13 08:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
the second one is what is on my 68.
Re: map light harness 2 [Re: CSK] #1537342
11/21/13 11:15 PM
11/21/13 11:15 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
The one in the second photo is the correct map light for 1968-1970 Dodge and Plymouth B-bodies
