Re: 340 roller cam
[Re: GKMOPAR]
#1537159
11/20/13 08:51 AM
11/20/13 08:51 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
Since you are looking at a 70 340 block, I thought that I would ask this question. I found on the Hughes websight that a LA block could come from the factory with three different types of chamfers on the lifter bores. None, small, and a large chamfer. They say that before cosidering a Roller cam, the size of the chamfer should be looked at. I would like to upgrade to a roller sometime next year but after finding this info, I am not sure how big of a chamfer is too big. I have attached a picture of my 70 340 block for reference. How big of a chamfer is too large? Sorry for jumping in, but this might affect your situation too. It appears that Hughes has a lifter that may fix this issue.
Note: I am also curious about the size of roller cam for your 340 rebuild.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: 340 roller cam
[Re: YO7_A66]
#1537160
11/20/13 08:52 AM
11/20/13 08:52 AM
YO7_A66
Indiana
This is the picture off of the Hughes web sight for reference.
""For use in LA blocks with hydraulic roller camshafts. Sets include link bars. Before purchasing the HUG5008A retro-fit lifters, be sure to check the lifter bores in your block. The photo below shows an unmolested 360 small block. As pointed out by the arrows, some of the lifter bores are chamfered, or counter-bored. We do not know why Mother Mopar chose to do this. As you can see they are randomly bored to differing depths. The problem with this is that when you want to retrofit your block to a hydraulic roller cam the lifters that you need to use may come up high enough that the oil groove around the outer perimeter of lifter becomes exposed into this chamfer. This is not acceptable. If your block has these chamfers, you can usually use our HUG5321 lifters with the lowered oil band that will work on these blocks.""
Re: 340 roller cam
[Re: 1972CudaV21]
#1537163
11/20/13 12:04 PM
11/20/13 12:04 PM
dogdays
It is a counterbore, not really a chamfer, either way it COULD be cured by sleeving the lifter bores, which would also put them in the right location three-dimensionally, though it's costly to do so.
Remember that these were passenger car blocks, and the way Chrysler operated, anything that wouldn't get a new car back to the dealership for warranty work was pretty much OK. That's why their balancing was the worst of the Big Three, and they were the only car builder to use oversize lifters, undersize crank journals, and a few other things in order to get fewer pieces going into the reject bin.
R.
Re: 340 roller cam
[Re: GKMOPAR]
#1537164
11/20/13 02:23 PM
11/20/13 02:23 PM
YO7_A66
Indiana
""Two cams I have been looking @ are the Lunati Voodoo 20200712LK and the comp Thumper CL20-600-9. Can I get some feedback on this?
bump
Re: 340 roller cam
[Re: GKMOPAR]
#1537166
11/20/13 05:57 PM
11/20/13 05:57 PM
Posts: 15,487 Florida
scratchnfotraction
I have never tried one but I have read that a roller cam will allow you to use a larger cam without sacrificing some drivability. I am building a street 340 to 1970 specs. It is 0.30" over and balanced but otherwise stock. I am running in a Demon with a 4 speed and a 3:55 gear. I know I also need to run a bronze drive gear. Two cams I have been looking @ are the Lunati Voodoo 20200712LK and the comp Thumper CL20-600-9. Can I get some feedback on this?
the lunati voodoo roller cam 60710 I ran was a cast core and does not need the bronze gear for intermed shaft.
a billet roller cam core will need the bronze gear.
and i think they do a billet roller cam core with a pressed on cast iron gear so no bronze gear is needed.
never heard of the counter bore thing before...but a non-roller 340 block will need some clearancing in the vally on back side of roller lifter link arm and for a tall lifter to drop down in the bore.
the counter bore on the pic looks sort like the machined area for dogbones on factory roller cam blocks. the block has taller bores and a counter bore for the dogbones to fit in and help keep roller lifters straight in the bore.
I ran my lunati roller with comp 901-16 spring with all stock roller gear. done about 5 lunati SB cams with the comp 901 springs,lunati specs the spring as the same for all SB cams flat & roller.
I just swaped in the hughes whiplash with comp 901 springs and stock roller valve gear. cam specs are almost exact between the whiplash & voodoo
the retro roller cam valve gear is where the $$$ & machine work come in on the build.. lots of info needed here to get it to last.
and the billet radical cams and not valve gear freindly on the street.
I would look for the factory 68 4 speed only cam for the a 70 340
I like the whiplash flat and roller cams, they are for a lopo stock engine, lumpy and run great for daily street duty.
Re: 340 roller cam
[Re: scratchnfotraction]
#1537167
11/20/13 11:26 PM
11/20/13 11:26 PM
Posts: 698 Hilliard, Ohio
GKMOPAR
Hilliard, Ohio
Here are the specs of the two cams:
COMP Cams CL20-600-9 - Comp Cams Thumpr Hydraulic Roller Cams Details Valve Setting: Intake - Hyd, Exhaust - Hyd RPM Operating Range: 1900 to 5600 Cam Grind Number: 283THR7 Duration Advertised: Intake - 283, Exhaust - 303 Duration @ .050'': Intake - 227, Exhaust - 241 Valve Lift: Intake - .511, Exhaust - .497 Lobe Sep. Angle: 107° ----------------------------------------------------------------- Lunati VooDoo RPM Range: 2200 - 6200 Lift with 1.6 Rocker: .535"/.550" Duration @ .050": 231/239 Advertised Duration: 282/290 112/106: 110/106 Valve Lash: Hyd/Hyd Camshaft: 20200712 Complete Kit: 20200712K
Looks like Hughes has some comperable specs in their hydraulic roller selections. I see the writeup on the lifter bores. They recomment the HUG 5321 roller lifter with low oil hole.
HUG HER1828ALN-10 HYD ROLLER CAMSHAFT 110º LSA +3 HYDRAULIC ROLLER; NEW CORE 110º LSA Camshaft Technical Details Intake Valve Lift 1.5 .510" Exhaust Valve Lift 1.5 .510" Intake Valve Lift 1.6 .544" Exhaust Valve Lift 1.6 .544" Intake Duration at .050" 218° Exhaust Duration at .050" 228° Lobe Separation Angle 110º Intake Centerline 107º Intake Opening at .050" 2° BTC Exhaust Opening at .050" 47° BBC Intake Closing at .050" 36° ABC Exhaust Closing at .050" 1° ATC Min. Suggested Cylinder PSI 165 Sweet Spot RPM 1800 - 6100
Re: 340 roller cam
[Re: GKMOPAR]
#1537170
11/21/13 01:59 PM
11/21/13 01:59 PM
scratchnfotraction
Being a street car I would like a little lope @ idle but want something drivable that will pull good from about 1500-5500.Was trying to decide if a roller is worth the extra $ and if it would be worth it for my combo. Again just heard you can get more power with good drivability with a hydraulic roller on the street.
this is what I wanted and the whiplash roller fit the bill and very happy with it.
just plane sounds nasty at idle and smooths right out with light throttle. gave my 318 some nuts in the stepside truck.
Re: 340 roller cam
#1537171
11/21/13 05:04 PM
11/21/13 05:04 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I don't agree with the roller theory Until you get aggressive with ported heads and high lifts. The advantage of a roller is pretty limited on a low lift short duration cam. Looking at a flat lobe versus a roller lobe,the flat tappet has more low lift velocity. The roller doesn't lift the valve as much as fast down low. The only advantage in a mild application comes if your worried about flat tappet but a good oil prevents that You can buy a lot of food oil for the cost of going to a roller. Keith
Re: 340 roller cam
[Re: Dunnuck Racing]
#1537172
12/02/13 09:59 PM
12/02/13 09:59 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Call Mike Liston @ MRL Performance. I have a custom roller cam that he spec'd for me which is 227/231 .530"/.530" lift that idles cream smooth at 900 rpm and runs like stink...the engine made 470hp and 455 lb-ft with basically stock edelbrock heads, and 9.7:1 CR. He also has the right lifters at a reasonable price.
I used the Comp Cams beehive springs with the edelbrock heads since the edelbrock heads take chevy springs.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 340 roller cam
[Re: goldduster318]
#1537173
12/03/13 08:39 AM
12/03/13 08:39 AM
YO7_A66
Indiana
Do you mind telling me what your vacuum reading is at idle and what the LSA is on that cam? Thanks
Re: 340 roller cam
[Re: YO7_A66]
#1537174
12/03/13 11:53 PM
12/03/13 11:53 PM
goldduster318
Lake Orion, MI
its 110 LSA and the idle vacuum is 13-14 at 900 rpm with the clutch out (I have a 4-speed) Here it is running before I had the initial timing where it liked to be. It sounds LESS mean at idle now actually. https://www.youtube.com/watch?v=iXKZO7J8QawI don't know anything else about the cam specs. Like I said, Call Mike. It doesn't need a bronze gear either. We were both blown away at how good the engine turned out. Its not a super torque monster down low, but my car has 3.23's and its not like it has issues moving. When you get above 2500, this thing is a total monster. It makes 400 lb-ft or more from 2900-6000. I can leave 10-15' of rubber on the 1-2 shift at 52 mph. We used a lot of good parts in here. Nothing super exotic either.
