Mopar Performance Bronze Gear Wear
#1536720
11/19/13 12:09 AM
11/19/13 12:09 AM
Posts: 749 NY
Beep Beep
NY
When should I replace my distributor gear? The street stroker build is almost 2 years old and has 1900 miles. I have included a picture of the gear compared to a new gear. There is some wear on the teeth and also on the bottom wear it rides on the distributor bushing. Should I be replacing this? How many miles should I expect to get on a new gear. Oil is 15W50 and stock volume high pressure oil pump.
Re: Mopar Performance Bronze Gear Wear
[Re: Beep Beep]
#1536721
11/19/13 12:12 AM
11/19/13 12:12 AM
Posts: 749 NY
Beep Beep
NY
Pic #2
[Re: Beep Beep]
#1536723
11/19/13 11:32 AM
11/19/13 11:32 AM
RapidRobert
I'm assuming your app is one that is supposed to run the bronze gear? does your oil have enough zinc? It does look like the margins at the OD are thinner on the used one. You might put a screwdriver in the slot & see if there's any rotational play just like backlash on a ring/pinion
[Re: Stanton]
#1536726
11/19/13 08:53 PM
11/19/13 08:53 PM
Posts: 7,664 IN
ahy
IN
Why do we care about zinc with a roller cam ???
Roller followers don't care about zinc but the gears may benefit. 15W40 sounds like diesel oil so it probably has a good amount of zinc in any case.
I'm no expert but that gear looks pretty worn... I'd replace it.
Agree its a good idea to re-examine the HP pump and maybe oil. What are oil pressures running (hot idle and hot at speed)? The HP pump doesn't help at idle and may not be needed at speed. If you have more than 20 psi at idle I'd definitely try a thinner oil. Even lower idle pressure may be OK if it doesn't spend a lot of time there (race application).
[Re: Stanton]
#1536734
11/22/13 04:56 PM
11/22/13 04:56 PM
Posts: 4,179 California
mickm
California
Whoa! That gear from Hughes isn't "composite", its a coated steel gear. I'd take their advice about not using it on a used cam. But it would still be nice to know why not!
they told me that little bits of bronze from the gear are embedded on the surface of the teeth on the cam, and those will wear into the composite gear, destroy the coated surface and then it will wear just like a regular gear.
i was told if i wanted to use it on a used cam, that i would have to take the cam out and clean the teeth thoroughly.
[Re: Beep Beep]
#1536735
11/23/13 01:04 PM
11/23/13 01:04 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I'm going to have my next bronze gear cryogenically treated to see how that affects the wear.
Ditto on using thinner oil to reduce the load on the pump and gear.
The Milodon billet pump reportedly takes less power to turn at a given rpm, so I'm running one of those to reduce gear wear too. I have the stock cover on that pump. The shape of the gearator is significantly more pointed than the stock gearator, which is what supposedly allows it to pump the oil more efficiently.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Beep Beep]
#1536737
11/24/13 06:21 PM
11/24/13 06:21 PM
RapidRobert
See what you have for psi after the oil change
