Re: 3.9 to 360 swap. question about tq converter
[Re: AJP087]
#1534654
11/18/13 04:40 AM
11/18/13 04:40 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Most 360s I have ever dealt with used the 727 type heavy duty trans. What is this "push button overdrive trans" you are talking about? I believe the V6 would be using a trans based on the light duty 904 regardless of what it is called and if that is correct the V6 converter would have the smaller neck. Therefore the 360 converter would not fit into the V6 trans front pump. I would test fit the converter to the trans before I got too far down the road with this swap. Good luck.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1534655
11/18/13 06:45 AM
11/18/13 06:45 AM
Posts: 12 dfw, Tx
AJP087
dfw, Tx
push button is what i remember my dad refering to it as. His truck had a button on the dash to turn overdrive on and off. Its what the 360 is out of.
Could I just grind off the weight from the 360 converter and weld it to the v6 converter? Or will the v6 converter even bolt to the fly wheel.
