Holley fuel bowl inlet gasket?? #1533129
11/13/13 09:55 PM
11/13/13 09:55 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does anyone have a part number for the 7/8" gasket for Holley fuel bowl inlets??? I'd like to find something local so I don't have to wait for a delivery.
Thanks!!!
Re: Holley fuel bowl inlet gasket?? [Re: mopowers] #1533130
11/13/13 11:15 PM
11/13/13 11:15 PM
You can grab one of your unused gaskets & with a razor blade/exacto knife/hole punch (HF has a cheap set) or a combo of all 3 cut a simple gasket for that & get a better fit than the ID of alot of em in the carb kits. I do it regularly no problems
Re: Holley fuel bowl inlet gasket?? [Re: RapidRobert] #1533131
11/14/13 12:41 AM
11/14/13 12:41 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Original gaskets are rubber covered metal,can't duplicate those with a razor blade.
Re: Holley fuel bowl inlet gasket?? [Re: 62maxwgn] #1533132
11/14/13 01:11 AM
11/14/13 01:11 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Holley fuel bowl inlet gasket?? [Re: 340SHORTY] #1533133
11/14/13 02:10 PM
11/14/13 02:10 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks guys. None of the local parts stores had any of the Holley part numbers I found. I ended up cutting a couple of my own out of an extra metering block gasket I had. Great idea! We'll see if they leak tonight...
Re: Holley fuel bowl inlet gasket?? [Re: mopowers] #1533134
11/14/13 02:30 PM
11/14/13 02:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tognottis Auto / Truck
2509 Fulton Ave
Sacramento, CA 95821
ON corner of el camino and Fulton ave...
Tony
70 AARCuda Vitamin C
