small parts for R5 block
#1532734
11/12/13 08:36 PM
11/12/13 08:36 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I am missing some small parts for a complete R5 engine.
A few oil galley plugs that are held with snap rings. Think they were removed for inspection when building another block and got lost.
Need about a half set of head studs. Not sure what happened to this stuff.
The screw in plugs with the O-ring for the oil galley access on the side of the block as well as the water drain plugs. Should be the same.
I have attempted to reach the guy I bought the stuff from and have not heard back.
I don't mind buying these parts new but not sure what the correct terms for the parts are and who supplied them when new.
Leon
Re: small parts for R5 block
[Re: jg309]
#1532737
11/16/13 10:39 AM
11/16/13 10:39 AM
Leon441
Lynchburg, VA
I might call him if I don't come up with something from a small timer first. Would rather help a fellow racer as a first choice.
Leon
[Re: Jerry]
#1532739
11/16/13 10:51 AM
11/16/13 10:51 AM
Leon441
Lynchburg, VA
I have some of the O-ring boss plugs like used on fuel pumps and things. The thread and O-ring is correct. The problem I had with them is the hex head would not clear the block around the hole.
I will look and see if I can find some with the allen head in them. Thanks for the info.
Hopefully someone will come up with the galley plugs for the oiling circuits. I am missing three and would buy more just to have them. These are the ones held in by snap rings and have the 1/4" 20 thread hole to pull them out. The have a recess and oil ring for sealing the hole.
Leon
