Re: How does one know if their steering box is worn out?
[Re: 72demon416]
#1531759
11/11/13 10:57 AM
11/11/13 10:57 AM
RapidRobert
I'd start by grabbing the Pitman arm & moving it thru its' travel & as you know you'd want it to be smooth with no binding. then I'd put in the middle of its' travel & see how much play the horizontle shaft has. There is an adjustment procedure for the 2 adjustments & in order. I'd open the plug & see what you have for lube in there
[Re: 72demon416]
#1531762
11/11/13 09:46 PM
11/11/13 09:46 PM
RapidRobert
You're in good shape, the problem is elsewhere
[Re: RSNOMO]
#1531763
11/11/13 10:34 PM
11/11/13 10:34 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
If you're in this deep, why not pull it down and take a look???
Procedure is in the FSM...
Pretty straightforward...
Yeah....I might just do that to have a peek in there anyways- even if it is good..... Thanks guys!
