New or repop speedo cables available? #1531152
11/10/13 10:58 AM
11/10/13 10:58 AM
Puttin' on the foil in Charles...
not_a_charger Offline OP
Mr. Big Shot Moparts Moderator
My 73 Coronet wagon has a swapped-in 77 Cordoba tilt/cruise column. Does anyone know if the 2 cables for a cruise-equipped Cordoba are still available?
Earning every penny of that moderator paycheck.
DBAP
Re: New or repop speedo cables available? [Re: not_a_charger] #1531153
11/10/13 12:34 PM
11/10/13 12:34 PM
I used a "Pioneer" brand replacement speedo cable on my 65 dart. it was a fair amount longer than the OE cable so there was a longer arc in the eng compartment before it went down to the trans but it was doable. You might Google that name & see if you can locate what Pioneer has to offer
Re: New or repop speedo cables available? [Re: RapidRobert] #1531154
11/11/13 02:22 PM
11/11/13 02:22 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
redline built a very nice all metal ( inside ) cable for me.. Works great when the "new" cable I bought locally did not work.
They are in southern california.. Give them a call
