Dodge Avenger MAP #1531143
11/10/13 10:16 AM
11/10/13 10:16 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
My Grandson has a '98 Dodge Avenger 2.5L. He removed the intake plenum to replace valve cover gaskets. When he got it back together it had a 1297 MAP sensor code. He did not replace the plenum gasket. He replaced the MAP sensor still has the 1297 code. Idles erratically, dies when you take your foot off the gas. Plenum gasket vacuum leak?
Re: Dodge Avenger MAP [Re: TooMany62s] #1531144
11/12/13 12:42 AM
11/12/13 12:42 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
low vacuum. probably gasket, make sure all lines are hooked up. low vacuum will cause map sensor to read wrong.
