CRASH SHEETS #15306
04/27/05 11:08 PM
04/27/05 11:08 PM
Anonymous OP
Anonymous OP
SEE EDIT BELOW
I recently purchased some "crash sheets" for both 66-70 DODGE "B" body and 67-69 DART "A" body.
There is a frame diagram for both "B" and "A" body DODGE ONLY models.
These diagrams have critical frame measurements that can be used in conjunction with laser frame measuring equipment that body shops use for new car unibodies.
These measurement are critical for the frame to be put back in the proper place to insure the strength of a unibody.
If you are restoring or repairing one of these cars and it has had damage to the unibody this will allow your body shop to properly repair it so the car does not "fold up" if hit again with a weak spot in the unibody.
These are FREE to anyone that needs them.
Just send me your name and address and I will copy them and mail them to you.
Don't take a chance driving these high powered missles with a tweaked frame.
darryld1@cox.net
EDIT:
I just scanned this sheet and it came out well. I saved it at 850 pixels wide so the attachment will be reduced but when you capture it and blow it up it will be very readable
Re: CRASH SHEETS #15307
04/28/05 12:07 AM
04/28/05 12:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Thanks for being so considerate, helpful & generous! These (and others when possible) should be in the Archives! How 'bout it, mods?
Re: CRASH SHEETS [Re: topside] #15308
04/28/05 02:19 AM
04/28/05 02:19 AM
Anonymous OP
Anonymous OP
Your welcome.
