I just picked up an old race Hemi myself. It already has a 4.25 crank. From what I modeled up in excel I think a 1.5ch piston, 7.1" rod and 4.35 crank will work out pretty good. The longer rod drives towards better rod angle. If my spread sheet is close to being right, you should end up around 10.8:1 with a lot of assumptions for dome volume, chamber volume and gasket thickness.
The issue I have is that it looks like my pistons have a CH of 1.34" which is real short. I am trying to decide if I want to figure out how to use that (I haven't found any 7.2" rods) or go with new rods and pistons.
