Tire size help #1530438
11/09/13 03:00 AM
11/09/13 03:00 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Can anyone tell me what's the widest rim you can fit on a 69 charger not tubbed I have cal tracs on it in the stock leaf spring section. I'm looking at getting the right drag racing rims for next season. I'm using a 8 inch rim with 28/10.5/15 M/T slick. I was wondering if a weld 15x10 rim would work and what back spacing would I need or do I gotta go with a 9inch. Any help would be appreciated. Thanks
Re: Tire size help [Re: Cape] #1530439
11/09/13 02:25 PM
11/09/13 02:25 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Anyone know?
Re: Tire size help [Re: Cape] #1530440
11/09/13 03:49 PM
11/09/13 03:49 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
I can't help with the max wheel size, but you might consider a 9" slick. Had my best times and hook on the belvedere with a Hoosier 9 x 28 on 8" wheel. Had to readjust the clutch pressure & relearn to drive because it was dead hooking. Just a thought
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
