hemi heads set onto 440 block? #1529783
11/07/13 01:48 PM
11/07/13 01:48 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I was thinking they will but not 100%sure
would be just for a display only and know that 440 block dont have the inner head bolts but is it possible to put any head bolts in? motor not have any internals besides crank
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: hemi heads set onto 440 block? [Re: toplescuda] #1529784
11/07/13 01:56 PM
11/07/13 01:56 PM
One of the magazines decades ago actually welded bosses on the valley so as to use Hemi heads on a wedge (dont remember if it was a B or a RB) so if that is accurate then the rest of the bolt holes would have to of lined up. post pics when you're done
Re: hemi heads set onto 440 block? [Re: toplescuda] #1529785
11/07/13 02:11 PM
11/07/13 02:11 PM
AndyF Online content
AndyF  Online Content
Bolts on just fine for display purposes. You can also bolt the intake on. The exhuast manifolds might interfere with the wedge motor mounts.
Re: hemi heads set onto 440 block? [Re: RapidRobert] #1529786
11/07/13 02:12 PM
11/07/13 02:12 PM
dogdays Offline
dogdays  Offline
Yeah, they'll bolt on.
Years ago, there was a board member who ran Hemi heads on a 440 block. I think he just didn't use the valley bolt. His username was hemiman.
R.
Re: hemi heads set onto 440 block? [Re: dogdays] #1529787
11/07/13 02:20 PM
11/07/13 02:20 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Thats what i was wanting to know... i have a bare set of hemi heads and a intake valvecovers just thought id get a bare block to mock parts on and display it on stand
1971 charger
Re: hemi heads set onto 440 block? [Re: toplescuda] #1529788
11/07/13 07:37 PM
11/07/13 07:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I believe Stage V made hemi heads specifically for a 440 block and yes, bolt bosses had to be welded in the valley, which was probably the major drawback at the time. I imagine technology has now advanced enough that just about anyone could do that but with the availability of reproduction and aftermarket blocks, why go to all the trouble?
Anyhow, should make a nice display piece!!
Re: hemi heads set onto 440 block? [Re: Stanton] #1529789
11/07/13 08:29 PM
11/07/13 08:29 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...not with the "conversion" head.
Re: hemi heads set onto 440 block? [Re: thehemikid] #1529790
11/07/13 08:36 PM
11/07/13 08:36 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...valley.
Re: hemi heads set onto 440 block? [Re: thehemikid] #1529791
11/07/13 09:09 PM
11/07/13 09:09 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A long time ago !!
Re: hemi heads set onto 440 block? [Re: 62maxwgn] #1529792
11/07/13 10:27 PM
11/07/13 10:27 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
The destroked Hemis back in the day used a 383 block that looked like this:
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: hemi heads set onto 440 block? [Re: 62maxwgn] #1529793
11/07/13 11:11 PM
11/07/13 11:11 PM
Powell, Ohio ( Originally Pitt...
1970Dart3406 Offline
I remember those guys out of Pittsburgh. They had a 1970 Chrysler 300 with the conversion hemi heads on it. Wonder if they are still around? I was at their warehouse on time, had to be 20+ years ago.
