Re: Intake manifold to head spacers [Re: Crizila] #1529099
11/27/13 06:24 PM
11/27/13 06:24 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
pic4
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529100
11/27/13 07:28 PM
11/27/13 07:28 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
How about tig-welding the spacer around the intake port, then u only need 1 gasket. Just a thought.
Re: Intake manifold to head spacers [Re: rickraw] #1529101
11/27/13 08:08 PM
11/27/13 08:08 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Only using 1 gasket per side. The spacers are glued directly to the intake manifold without gaskets. Gaskets between the spacers and heads. Welding is a good idea, but this way I can "back up" if need be ( another intake manifold or different heads).
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529102
11/27/13 09:07 PM
11/27/13 09:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Could copy a gasket onto a 1/16" aluminum plate. It would cut & smooth pretty quick.
Leaning in that direction
And pleezzee tell me you`re not using cork end rail gaskets.........
Re: Intake manifold to head spacers [Re: Crizila] #1529103
11/27/13 10:19 PM
11/27/13 10:19 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Spacers look great.
Re: Intake manifold to head spacers [Re: Thumperdart] #1529104
11/27/13 10:47 PM
11/27/13 10:47 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Had to use them Dom. There was just too much space to fill with silicone alone. Glued them to the block and silicone between them and the bottom of the intake.
Fastest 300
Re: Intake manifold to head spacers [Re: Crizila] #1529105
11/27/13 11:06 PM
11/27/13 11:06 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
For those who have glued gaskets together, what did you use that's fuel-resistant? I may need to "build" some .090"-ish gaskets to get an intake to align with the heads properly.
Re: Intake manifold to head spacers [Re: BradH] #1529106
11/28/13 11:38 AM
11/28/13 11:38 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I use Permatex "High Tack". " Will not "dissolve by gasoline". I run race gas, so no alcohol in it.
Fastest 300
