Wow! I just might have found it. Repro dual quad base
[Re: DaytonaTurbo]
#152793
11/18/08 06:59 PM
11/18/08 06:59 PM
Posts: 238 St. Catharines, ON
NewMemberAgain
super street
super street
St. Catharines, ON
I was looking through a link froma link and it mentioned Year One. Oddly enough they do re-pop the dual quad base! Now to find the distance between the carbs. Hope it is the same, that would be great! Off to the A12 forum now... Bryan
Re: Dual quad air cleaner pics? What are you using? Pics?
[Re: NewMemberAgain]
#152795
11/18/08 09:09 PM
11/18/08 09:09 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
Well, oddly enough I will be building the exact same air cleaner soon for my Jensen Interceptor. I have a CH28 Edelbrock #5440, and I'm going to run an oval Mopar air cleaner on it. I'll post pics when I start... I have already made other unusual air cleaners, it's not THAT hard, just takes a little planning....
CrAzYMoPaRGuY
#152806
11/20/08 08:17 PM
11/20/08 08:17 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
I know this looks cheezy but I used a Moroso adjustable dual quad base with a couple of cheap Eddy air-cleaners. I had the Eddy Elite air cleaner but it would not fit under the hood. I am going to try and fab the Moroso base into an OEM base and use a regular air filter. Haven't tried this yet and hope it will hide the fact that there are two carbs...tee hee...
BigBlock 74 Swinger
[Re: bb74swngr]
#152807
11/21/08 01:09 AM
11/21/08 01:09 AM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
Not cheezy at all looks good. And the engine and compartment is very sanitary!
[Re: Greg55_99]
#152809
11/21/08 04:18 PM
11/21/08 04:18 PM
Posts: 1,615 Table Rock Lake Missouri
furious
This is what the stock 1962 300H 413 used;
Greg
I would love to have another set of those, the same ones were used on 58s up. I wish I still had a set like came on my 57 Furys, even cooler.
[Re: WO23Coronet]
#1802954
04/14/15 12:42 AM
04/14/15 12:42 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This is what the stock 1962 300H 413 used; Greg The 60 Dodge I'm buying comes with a complete long ram setup but it also comes with a set of those air cleaners that I may put on an Edelbrock CH28 with some Carters instead of the long ram, can you still get filters? Possibly !
[Re: CrAzYMoPaRGuY]
#1802967
04/14/15 12:53 AM
04/14/15 12:53 AM
62maxwgn
Blair County,PA
Well, oddly enough I will be building the exact same air cleaner soon for my Jensen Interceptor. I have a CH28 Edelbrock #5440, and I'm going to run an oval Mopar air cleaner on it. I'll post pics when I start... I have already made other unusual air cleaners, it's not THAT hard, just takes a little planning.... Remember,if you are running a CH28 and want to use the oval air cleaners,you have to run AFB's.Also there will be no clearance between the air cleaners,the carb spacing is about 3/8 closer than the factory intake. Here is my factory intake,everything from a 62 300H,
[Re: 62maxwgn]
#1803271
04/14/15 02:41 PM
04/14/15 02:41 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Well, oddly enough I will be building the exact same air cleaner soon for my Jensen Interceptor. I have a CH28 Edelbrock #5440, and I'm going to run an oval Mopar air cleaner on it. I'll post pics when I start... I have already made other unusual air cleaners, it's not THAT hard, just takes a little planning.... Remember,if you are running a CH28 and want to use the oval air cleaners,you have to run AFB's.Also there will be no clearance between the air cleaners,the carb spacing is about 3/8 closer than the factory intake. Here is my factory intake,everything from a 62 300H, Can you use AVS's on the CH28?
[Re: 62maxwgn]
#1803324
04/14/15 03:43 PM
04/14/15 03:43 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Are the air horns different sizes?(think they're the same) or is there some sort of interference? (Linkage etc)
