7 1/4 to 8 3/4 on A-body #152646
11/17/08 09:15 PM
11/17/08 09:15 PM
Missouri
Confusedcuda Offline OP
Missouri
Hey guy's. Just about got everything for my 7 1/4 to 8 3/4 conversion. Will the backing plates from my 7 1/4 fit my 8 3/4? This is a 67 barracuda with 10" drums. Thanks
Re: 7 1/4 to 8 3/4 on A-body *DELETED* [Re: Confusedcuda] #152647
11/17/08 09:38 PM
11/17/08 09:38 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Post deleted by DusterKrazy
Re: 7 1/4 to 8 3/4 on A-body [Re: DusterKrazy] #152648
11/17/08 09:45 PM
11/17/08 09:45 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I think you have to add the 5th hole
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 7 1/4 to 8 3/4 on A-body [Re: DusterKrazy] #152649
11/17/08 09:47 PM
11/17/08 09:47 PM
Missouri
Missouri
That's what I was thinking, but the different diameter of the housing got me wondering. Anyone else?
Re: 7 1/4 to 8 3/4 on A-body [Re: Confusedcuda] #152650
11/17/08 09:49 PM
11/17/08 09:49 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
I'm thinking they will not work. The 8 3/4 has 10 inch drums, while the 7 1/4 has 9 inch drums.
Re: 7 1/4 to 8 3/4 on A-body [Re: monoptn] #152651
11/17/08 09:57 PM
11/17/08 09:57 PM
they wont interchange, offset is different
Re: 7 1/4 to 8 3/4 on A-body [Re: monoptn] #152652
11/17/08 10:08 PM
11/17/08 10:08 PM
Lake Orion, MI
Lake Orion, MI
my car had a 7.25 with 10" drums. they made v8 cars (which came standard with 10" drums) with 7.25's
Re: 7 1/4 to 8 3/4 on A-body [Re: Confusedcuda] #152653
11/17/08 10:11 PM
11/17/08 10:11 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
You will need plates from a 8 1/4 or 8 3/4, the 7 1/4 ones will not work.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: 7 1/4 to 8 3/4 on A-body [Re: Ryan_340] #152654
11/18/08 12:46 AM
11/18/08 12:46 AM
Missouri
Missouri
Okay, Now I am confused, I am Pretty sure my 7 1/4 has 10" backing plates. It seems a lot of 8 3/4 have 10'' plates on them stock. I did have to change U-bolts and Spring plates, but I would think my backing plates would work. I need all the opinions I can get. Thanks
Re: 7 1/4 to 8 3/4 on A-body [Re: Confusedcuda] #152655
11/18/08 01:13 AM
11/18/08 01:13 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I'm almost positive that the diameter of the flange end/brg is different so the diameter of the bolt circle on the plates is different.
I know that some 8 1/4's had only 4 holes, and you could knock in the 5th hole to make it work, but not on a 7.25.
I don't think you'll know for sure till you try, but I doubt very much it will work
Re: 7 1/4 to 8 3/4 on A-body [Re: Confusedcuda] #152656
11/18/08 01:16 AM
11/18/08 01:16 AM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
The 7 1/4 plates have 4 bolt holes for the axles, the 8 3/4 have 5.
Re: 7 1/4 to 8 3/4 on A-body [Re: Ryan_340] #152657
11/18/08 01:23 AM
11/18/08 01:23 AM
Missouri
Missouri
You guy's are right! I just went out and looked and my 7 1/4 plates have 4 holes and the flange on my housing has 5. I need to get some plates now. Should any 8 3/4 10'' backing plate work or do they need to be A-body correct. I have all ready found some cheap on evilbay from a 8 3/4 B-body but they look exactly the same. Thanks a million....
Re: 7 1/4 to 8 3/4 on A-body [Re: Confusedcuda] #152658
11/18/08 09:10 AM
11/18/08 09:10 AM
scratchnfotraction Offline
what axles do you have? stock A-body? stock A-body housing? did you have one cut down to A-body specs?
as long as you have axle with the large brake offset,B-C-truck 8 3/4 axles,or moser axles or some other after market axles
7 1/4 wont work and the skinny A-body 8 3/4 brakes wont work with the large brake offset axles
any brake set up of a 8 3/8,9 1/4,8 3/4,9 3/4
A,B,C-body and truck will work
I used 73 bp and 11x2.5 brakes from a 73 newport on my 68 dart going from 7 1/4 to 8 3/4,I did up to the largest wheel brake cyls
11s are a little big/heavy,but the stopping power over the 10s was very noticable with hard braking,auto-x style,almost no fade
I had the large 12" rotors from an R-body on my A-body spindles with a MP 4 bolt mc to 2 bolt alum mc adapter with a 79 truck alum mc,all manual brake even had air scoops on the front dust sheilds for cooling of the rotors
braking power is transforming friction into heat,bigger is better
