Acceptable Converter slip numbers *DELETED*
#1526083
10/30/13 10:49 PM
10/30/13 10:49 PM
Posts: 3,416 Toronto
mshred
Toronto
Re: Acceptable Converter slip numbers
[Re: moparguy7074]
#1526085
10/31/13 09:13 AM
10/31/13 09:13 AM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
9" Dynamic flashes 5800 to 6000 rpm. best 9.61 @ 193.2 mph.
Slips less than 5% per data recorder.
[Re: markz528]
#1526086
10/31/13 10:39 AM
10/31/13 10:39 AM
Posts: 1,552 Michigan
Kiddart
run your numbers thru the wallace calculator www.wallaceracing.comThere is a magic number i was told 5% anything over that you are leaving ET on the table
Thank you Kiddart
[Re: dizuster]
#1526089
10/31/13 12:25 PM
10/31/13 12:25 PM
Triple Threat
Renton Washington
My 8" Ultimate converter slips 12% ish can't get too exact without a data logger.
[Re: MadMopars]
#1526091
10/31/13 12:37 PM
10/31/13 12:37 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
Mine figured out to 5.33%. Turbo Action 10" conveter. The car is a 69 Satellite. 3850lbs with driver. 411 gears, 27" tire. Flashes to 3800rpm, 6000rpm at the stripe. Runs 12.10 at 111mph....
[Re: jamesc]
#1526095
10/31/13 03:57 PM
10/31/13 03:57 PM
BradH
are you guys calculating converter slip taking into account tire growth?
Or, in the case of radial tire users, that the "squat" they have under load actually reduces the effective radius, even at speed?
FWIW, my 9.5" Dynamic advertised as a 4200-stall unit flashed to ~ 4500 w/ my last 440 and calc'd slippage in the 7-8% range.
[Re: mshred]
#1526098
10/31/13 06:24 PM
10/31/13 06:24 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
My Turbo Action 8" slips 6% according to Wallace. I think it needs to be loosened up to help my launch, its a 4500 and I think a 5000 would do my 360 some good.
I run a radial tire and while they are not supposed to grow I have a pic of mine on the top end and they visually look to have grown some and its not even that fast...117mph on that run.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1526099
10/31/13 07:04 PM
10/31/13 07:04 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Mine says 2.89% according to wallace. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
