Re: recommendation for single wire alternator? 71 Dart
[Re: cal_gecko]
#1524570
10/28/13 10:11 AM
10/28/13 10:11 AM
RapidRobert
I would suggest staying with the OE setup, either a 78 amp alt from a mid 80's M body or a denso If you can do some slight mods so it will mount up.
[Re: cal_gecko]
#1524571
10/28/13 01:41 PM
10/28/13 01:41 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
Was it a GM guy? They LOVE one-wire alternators. I would go to your friendly neighborhood parts store (Kragen, Parts City, etc.) and get one of their alternators, WITH some kind of warranty. If it fails (and if it's a bad one, it probably will w/i a year) you get another one. I know around here, the local rural mail carriers get all their parts like that, because their junk usually fails eventually with that kind of hard use...and then they get replacements.
ex-Ford guy, but Mopars nowadays
[Re: cjbill]
#1524572
10/28/13 04:09 PM
10/28/13 04:09 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Actually, it is the one guy at the shop who also has a 71 Swinger that he's got set up pretty nicely.. what's the disadvantage of a 1-wire over the OE setup? Seems like it would be a better option (less wiring = less opportunity for problems)
[Re: Challenger 1]
#1524577
10/30/13 12:16 PM
10/30/13 12:16 PM
Posts: 2,432 NorCal
RylisPro
NorCal
What's wrong with using a one-wire alternator? I bought my Powermaster 140 amp 8-47529 back in 2004 (have the receipt to prove it), have used it daily and it is still going strong As long as your battery is fully charged you should be fine http://www.powermastermotorsports.com/mopar_high_amp.html
