208 - 205 #1521028
10/21/13 05:22 PM
10/21/13 05:22 PM
Iowa
76dodgeboy Offline OP
Iowa
Does the 208 share the same trans to t-case bolt pattern as the 205
Re: 208 - 205 [Re: 76dodgeboy] #1521029
10/21/13 06:50 PM
10/21/13 06:50 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I do believe they were the same, the only one that's different is that fulltime cast iron thing that I throw away.
Re: 208 - 205 [Re: 76dodgeboy] #1521030
10/21/13 09:41 PM
10/21/13 09:41 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
yes the 208 and 205 have the same bolt pattern and use the same coupler, there are both 29 and 31 spine NP 205s.. Need to know what you have vs what you need...
Re: 208 - 205 [Re: RODHALL] #1521031
10/22/13 01:46 AM
10/22/13 01:46 AM
Iowa
Iowa
Ok. I picked up a Np435 with a 208. I never gave the bolt pattern a thought. I plan to bolt the Np435 to the 205(gas)It looked the same. I didnt want to seperate the 435 from the 208 yet. Thanks
Re: 208 - 205 [Re: CTD5.9] #1521032
10/22/13 01:47 AM
10/22/13 01:47 AM
Iowa
Iowa
What full time cast Iron thing?
Re: 208 - 205 [Re: 76dodgeboy] #1521033
10/22/13 02:24 AM
10/22/13 02:24 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I think he means the 203 pos.
Re: 208 - 205 [Re: 77ProStreet] #1521034
10/22/13 03:33 AM
10/22/13 03:33 AM
Iowa
Iowa
I miss read his post. I knew what he was getting at. Couldnt have been too bad if they put them in Every 75-79 W series truck. The axles are what caused problems and mainly do to lack of service.
Re: 208 - 205 [Re: RODHALL] #1521035
10/22/13 07:22 PM
10/22/13 07:22 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
All the Gas Truck output shafts are 23 Spline on a 435 or 727..
Only the Manuel Diesels where 29 Spline output shafts
www.Greensburgmachine.com
