Cummins Tranny interchange #1520849
10/21/13 12:34 AM
10/21/13 12:34 AM
The Dalles, OR.
Dusted_Ya Offline OP
The Dalles, OR.
Is the Cummins 727/518 bellhousing bolt pattern the same as the small block pattern?
Retired Mopar fanatic
Re: Cummins Tranny interchange [Re: Dusted_Ya] #1520850
10/21/13 07:43 AM
10/21/13 07:43 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
No,just cummins. And v-10
Re: Cummins Tranny interchange [Re: d-150] #1520851
10/21/13 10:34 AM
10/21/13 10:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The 518 I believe is just cummins but the 727 used an adapter plate from what Ive been told but the certain parts inside need swapped as they are specific to work with the low rpm of the cummins
Re: Cummins Tranny interchange [Re: 76dodgeboy] #1520852
10/22/13 12:17 AM
10/22/13 12:17 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I just called a friend that knows all there is to know about Cummins and other Mopars.
He confirmed that the V10 shares a bellhousing with the Cummins when the adapter plate is used.
All the Cummins use the adapter plate, but the plate is different for each generation.
And unfortunately it is not a small block pattern bell.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Cummins Tranny interchange [Re: hp383] #1520853
10/22/13 09:38 AM
10/22/13 09:38 AM
Guitar Jones Offline
The Viper V10 uses the same bell housing bolt pattern also.
