yep full of h20
check the vents on the tube of the axle
I usally put a rubber hose from the vent up high in the frame,then make a small loop at the end to make an air pocket for deep wheelin in water
the 9 1/4 has a hole drilled in the tube with cover tac welded on over it
pry that off and tap theds in the tube,put a brass hose nipple in and run a hose up and do the loop thing
that will slow the water getting in down a lot
if its beeen stuck and the axle under any water mud it will go right in the 9 1/4 axle vent,same on the d44 front end
and what they said about condensation build up with one sitting,shows up as rust on the ring gear also pitting the teeth
clean it out and add some 90-140 gear oil and hope the bearings arnt hurt,if it makes a steady roar its prob the carrier bearings if it whines on the gas and off the gas its prob the pinion bearings,never know it just could be the axle bearings and not the chunk...so check them also.IMO
9 1/4 are bad on the carrier bearings but other wise they are a tuff rear axle
if it has a sg in it make sure to add the additve for them
if its not going to quite down,add some lucas oil additave to it to thickin it up
check the pinion nut to make sure its not coming loose,they are known for that also
clean out and driv it,bout all you can do when ya find it like that
good luck with it
