Re: case only difference between BB vs SB 727?
[Re: weedlayer]
#1519925
10/19/13 12:09 PM
10/19/13 12:09 PM
Posts: 168 Torrance, Ca
Fig
Torrance, Ca
I'm not a 727 expert, but I cant think of one part that is not interchangeable. I lifted this off of another web site if you want to verify big or small block: It's EASY to tell them apart if they're not attached to an engine. Course, I take for granted you can tell a 727 apart from a 904 from the pan. However, big and small block 727s are simple to distunguish. The small block version only has two torque converter dust cover retaining bolt holes across the bottom of the bell housing. The big block version has four. Of course, the bolt patterns are different, but the dust cover bolt holes are an easy fast way to tell. ____________________ Read more: http://forums.moparmusclemagazine.com/70.../#ixzz2iBMbvBn8
1937 Plymouth R/S Coupe 440/727
[Re: HPMike]
#1519928
10/19/13 03:09 PM
10/19/13 03:09 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Also, the mounting bolts for the struts on the SB case require a large diameter hole at 8 and 4 o'clock
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: weedlayer]
#1519931
10/20/13 08:14 AM
10/20/13 08:14 AM
Posts: 138 central pa
darted1
central pa
If I remember correctly small block uses a bolt at the top center of bell housing to attach to the motor. the big block doesn't their top bolt holes are at like 11 0clock and 1 oclock so there shouldn't no bolt hole at the top of the big block bell housing.
ED M
[Re: darted1]
#1519932
10/20/13 09:17 AM
10/20/13 09:17 AM
Posts: 119 SE VA
hemibee69
SE VA
That is how I differentiate small to big block bellhousing. If it has a bolt at the top in the center it is a small block. Easy and quick to see. JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly) 1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph 1970 Challenger SE 383 4 bbl A/C PB PS Leather 1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
[Re: hemibee69]
#1519934
10/20/13 03:54 PM
10/20/13 03:54 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No hole at top center.
