EMC 2013 470 B stroker build
#1518908
10/17/13 12:28 PM
10/17/13 12:28 PM
Posts: 1,051 The Great White North
RAMM
Like title says , I thought seeing what went into this build would be of interest to some so here is what it took to build a budget conscious Mopar stroker for use in the 2013 EngineMaster's Challenge. The 3 main rules were 3000-7000rpm test range, hydraulic lifters, 11.5 comp, 1.75" throttle bore carb (Holley 950 Hp)
At the contest it made peaks of 755 hp and 674 lbs.
Rundown: 400 block circa '75 (short fill), stock steel 440 crank final cubes came in @ 466 Bore 4.361" Stroke 3.900" (small error in offset resulted in .015" less stroke) 6.135" Scat BBC rods Icon 826 pistons with 1.867" CHT CompCam roller 256/260 @.050" .750/.708" 106 LSA Custom 1/2" girdle with aluminum main cap spacers internal oil p-u 1/2" NPT Cloyes Hex-Adjust timing set ProComp heads 2.25" (hollow stem) 1.75" Indy 400-2 intake Schoenfeld 1 7/8-2" dyno/sprintcar headers
This was to be our development engine to beat on trying different parts/configs. I had most of these parts on hand and wanted to get it together, test things out and then build a copy with much nicer parts and a few more tricks with what we learned testing this one. I had this engine running late August and was surprised it made pretty good power considering the low buck nature of it. Our first test up to 6500 rpm netted peaks of 708 hp/638 ft/lbs @ 32 total. Our first pull to 7000 rpm dropped to 508 hp @ 7000 rpm! Due to lifter instability.
I know I am forgetting things to post about this build. Ask away. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: EMC 2013 470 B stroker build
[Re: RAMM]
#1518909
10/17/13 12:30 PM
10/17/13 12:30 PM
RAMM
Here is where most of my attention went. You can see how much angle milling the heads changed the shape of the chambers.
In this shot you cannot see that I relocated the dowel position .100" to move the valves closer to bore centerline. J.Rob
[Re: RAMM]
#1518910
10/17/13 12:34 PM
10/17/13 12:34 PM
RAMM
Another shot of the 3.125" intake openings. Flow topped out at 360-363cfm from .700-1.00". I was after stability not flow rates. J.Rob
[Re: RAMM]
#1518911
10/17/13 12:36 PM
10/17/13 12:36 PM
RAMM
Here is a shot of how terrible the valve position is. Notice how the valve wants to open right into the exhaust side of the cylinder. J.Rob
[Re: RAMM]
#1518913
10/17/13 12:43 PM
10/17/13 12:43 PM
RAMM
The main girdle was probably the most fun and straightforward part of the bottom end. I milled it out from a solid blanchard ground steel. I didn't feel like messing around with some shim arrangement so I milled the tops of the main caps flush with the bolt holes and measured the distance between them and the girdle. Aluminum "cap straps" were made in that dimension fitted per cap to act as the spacer between cap and girdle. I feel that these would still give some of the benefits of a an aluminum cap and still be as stable as an iron cap. I think it worked quite well. J.Rob
[Re: RAMM]
#1518914
10/17/13 12:47 PM
10/17/13 12:47 PM
RAMM
Here are the Icon pistons before and after I moved the valve notches back and corrected for angle of the valves. J.Rob
[Re: RAMM]
#1518915
10/17/13 12:50 PM
10/17/13 12:50 PM
RAMM
Here is a shot of the completed shortblock. You can see the big dish I had to put in the top of the piston. J.Rob
[Re: BradH]
#1518920
10/17/13 01:51 PM
10/17/13 01:51 PM
RAMM
Yes on the images Brad. I have a hard time making them small enough usually for Moparts--now they are too small.
I would also like to give a big thanks to Rick @ FireCore 50 for his awesome support and products he supplied me. In the very near future I will be doing some A-B-A testing of his ignition products. I am expecting some solid results based on what I have already experienced. J.Rob
[Re: RAMM]
#1518921
10/17/13 01:56 PM
10/17/13 01:56 PM
BradH
Questions: 1. Got a full-curve flow chart for the heads? 2. Got dyno data for a representative 3000-7000 RPM pull? 3. How did the results from your dyno correlate to the EMC dyno? 4. What did you run for valve springs to support that much lift? 5. What would you change to "detune" it for a more street-friendly & reliable combination? That's all for now... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: RAMM]
#1518922
10/17/13 01:57 PM
10/17/13 01:57 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What lifters did you end up using?
Mopar to the bone!!!
[Re: RAMM]
#1518923
10/17/13 01:58 PM
10/17/13 01:58 PM
RAMM
I would also like to thank my buddy Joe who did such a nice job on the crank. This crank was a 40+ year old 440 steely that I tig'd the undercuts on the rods up and he offset ground and cut .300"+ from the counterweights. We profiled and cleaned the counterweights up as well. It took 2 slugs of Mallory to get it to balance. Bobweight was 2268g, no lightweight here. J.Rob
