valve spring shims #1518284
10/15/13 10:42 PM
10/15/13 10:42 PM
Illinois, USA
jeff1974 Offline OP
jeff1974  Offline OP
Illinois, USA
Probably a stupid question, but, when you shim valve springs to decrease the height...does the shim go on the spring seat, or under the retainer ? Don't laugh, I really am not sure about this one. Thank you.
Re: valve spring shims [Re: jeff1974] #1518285
10/15/13 10:45 PM
10/15/13 10:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It goes under the spring or under the spring cup if used.
