Page 3 of 3 1 2 3
Re: 4" Stroke Small block [Re: BJS racing] #1517998
10/16/13 09:01 PM
10/16/13 09:01 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
I run stock 360 block std caps studs top and bottom 3/4 fill ,never dynoed it, at 3550 1.37 60 ft 6.0 113 and 9.57@142 over 750 hp would be my guess
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: 4" Stroke Small block [Re: BJS racing] #1517999
10/16/13 09:39 PM
10/16/13 09:39 PM
dogdays Offline
dogdays  Offline
A 340 piston weighs in at 720 grams, the 360 piston at 571, IIRC. There's NO WAY the 0.040" difference in bore could make a 150 gram difference.
Basically if you calculate that weight increases by something like the square of the diameter change, the piston should have weighed another 10 or 20 grams, or something like a 318 piston, at around 590 grams.
BTW, the 318 Poly, the early LA 318 and the 273 used THE SAME FORGING for the connecting rod. It weighed something like 725 grams. The 496 rods used in the 340, and the 645 rods used in the 340,360 and later on the 318, weighed 758 grams.
Put those overweight rods together with the overweight pistons and you see that 340s had a very portly rotating assembly. It should be easy to take a half a pound out of each piston/rod combo.
R.
Re: 4" Stroke Small block [Re: BJS racing] #1518000
10/16/13 10:41 PM
10/16/13 10:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
just curious to why your going with the 3.79 vs the 4.00 stroke. seems like more cubes the better. what are the benefits of the shorter stroke?
A shorter stroke engine it is easier and quicker to go up in the RPM's. Typically with a shorter stroke engine you can turn more RPM than with the longer stroke due to the rotating weight and centrifical forces that are increased as your stroke gets longer.
Then why stroke it at all?
Why not shorten up the stroke? I have seen a few cranks under 3 inch stroke for the SB, those motors must have been real fast
BTW A shorter stroke tends to end up with heavier reciprocating parts, ever compare 340 and 360 pistons?
Measure the bore difference and then ask again. Yes the 340 piston is heavier because it is a bigger bore. Go find some 318/340 stock rods and weight them against a 360 stock rod. Then just for kicks weigh them all against a 273 rod. The 360 rod is the heaviest out of them all. 318/340 use the same rods. Why is that? Not trying to start any kind of anyone is wrong kinda deal. Just going with like I said earlier what I know and what I've been told.
I don't know many that put stock rods in a stroker making much steam . I didn't even use them in my 340 build years ago.
I was using as a base idea for the arguement. Aftermarket makes the same rod for all three. same weight and what not and he would be correct that the 340 piston would weigh more because it is bigger in bore size.
The 340 piston is a lot heavier because it is a lot taller due to the shorter stroke. The .040 bore is insignificant compared to that. You have also received some bad information about what rods came in what SB... the 273-and 318 used the same rods even the poly 318 until 69 at witch point they did away with the 273 and began using the 340 rod in the 318 and when they came out with the 360 it got the same rods. The only real differance is the 340 rod was bored and honed out to fit a bushing. All 318s and 360s after the early ones used the same "645" rod even the magnum rods starting in 92-93 that were narrowed just a hair on the small end. The early 273-318 rods are the lightest and have bushings for floating pins. All other SB rods besides the early 273-318 rod are almost the same weights and are interchangable. Before the aftermarket was flooded with cheap rods a lot of guys put the early 273-318 rods in the 340-360 to lighten them up a little and get floating pins. Every single SB rod ever stuck in an engine at the factory was the same length.
Re: 4" Stroke Small block [Re: qwkmopardan] #1518001
10/16/13 11:39 PM
10/16/13 11:39 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
This thread about if you can use a stock block and have success with a 4" crank and w-2 heads.
I have a bunch of high HP engines with stock 340/early 360 blocks, [basicly the same as a 340 casting], in service at this time. I have done them with the 4 bolt caps and my opinion it only adds to the cost of the finished project. Same with roller cams, No more power just a lot more money. In fact a couple times I have removed roller cams from customer engines and installed flat tappet cams and car has gone faster. Roller lifters fail and have ruined many a good bottom end. The only block failures I have experienced were due to other parts failing first.
well if removing the solid roller made the car go faster than the rest of the combo was not correct to begin with.
In a correct combo a solid roller WILL be faster. Oh and I have run many rollers including in a daily driven Vette and have never had a lifter failure.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 4" Stroke Small block [Re: dusturbd340W5] #1518002
10/17/13 12:30 AM
10/17/13 12:30 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Way to little or way to much spring can contribute to a failure with rollers, but if correct, they live happily for a long time.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 4" Stroke Small block [Re: B3422W5] #1518003
10/17/13 11:06 AM
10/17/13 11:06 AM
Az
Crizila Offline
Crizila  Offline
Az
,but the problem with rollers is they need a lot of spring ( in a racing application ) due to the lobe profiles and the addidional weight over flat tappet stuff. It's the down side of roller cams / lifters. In milder cam applications (.600 lift area and under ), flat tappet cams compete quite well with roller cams. IMO, roller cams are over sold. Did I mention a lot less moving parts to fail with flat tappet cams. Sorry this is so far away from the OP's original question.
Fastest 300
Re: 4" Stroke Small block [Re: Crizila] #1518004
10/17/13 12:16 PM
10/17/13 12:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
bull there is no reason to ever run a flat tappet with today's technology.
Re: 4" Stroke Small block [Re: Quicktree] #1518005
10/17/13 12:47 PM
10/17/13 12:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yup..................
Re: 4" Stroke Small block [Re: Quicktree] #1518006
10/17/13 01:31 PM
10/17/13 01:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
COST
Re: 4" Stroke Small block [Re: HotRodDave] #1518007
10/17/13 01:36 PM
10/17/13 01:36 PM
Az
Crizila Offline
Crizila  Offline
Az
COST
Yup! I run a pretty small blower cam. .550 lift range, 114 LSA. Running a roller would be a waist of $.
Fastest 300
Re: 4" Stroke Small block [Re: Crizila] #1518008
10/17/13 03:13 PM
10/17/13 03:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I looked hard at a solid roller when I built my 550ish stock block pump gas 408 and didn't see the advantage for the costs at this level. If I'd had a X or R block maybe, but I wasn't going to push my luck with a stock block.
Re: 4" Stroke Small block [Re: 1967dartgt] #1518009
10/26/13 10:21 AM
10/26/13 10:21 AM
East Palestine, Ohio 44413
Metallidart Offline
Metallidart  Offline
I ran one for a while 421" with eddies,then battens and finally indys had a 618 roller and many nos passes. 69 340 block with stock caps, sold it to a guy in Ohio so it might still be running.
That would be me, lol. Still working on collecting parts, I bought a 7 bedroom house that needed remodeled so that slowed me down alot. Still keeping my fingers crossed, it won't be at the rpms or power level you had it, so it might last awhile. Its getting a pair of ported long-valve Econo W2's and thick head gaskets for a drop in compression to about 10.4, and a solid custom grind cam in the upper 260's/270's@.050. I doubt I will be close to the 600hp mark, and I won't be running any NOS or anything.
Re: 4" Stroke Small block [Re: BJS racing] #1518010
10/26/13 10:50 AM
10/26/13 10:50 AM
Moparts
SSDart Offline
SSDart  Offline
Moparts
But what about the better rod ratio with the 4" stroke? Better piston speed....... lighter piston....... Yes a shorter stroke does do as you say above, but with the tall deck of the SBM it is a little different story.......
Re: 4" Stroke Small block [Re: SSDart] #1518011
10/26/13 02:13 PM
10/26/13 02:13 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I am using a magnum 5.9 block, 4" crank, Iron Ram heads, eagle rods, ross pistons at 12 to 1 comp. Its in a 3300lb Volare running mid to high 10's at 122 mph. Been doing it for 7 years also. I did do a cam change a few years ago. Other than that, never taken a valve cover off it. Its a work horse! We guess its making arount 530 hp with no adders.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Page 3 of 3 1 2 3
