What IS this? (71 E-Body firewall thingy) #1517914
10/15/13 04:26 PM
10/15/13 04:26 PM
Somewhere near Palm Springs
ConvertiBee Offline OP
I hav'nt a clue, and it arrived un-hooked to anything when I got my Cuda a couple of weeks ago...
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: What IS this? (71 E-Body firewall thingy) [Re: ConvertiBee] #1517915
10/15/13 05:18 PM
10/15/13 05:18 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
Do your road lamps work?
Couple guess' would be;
road lamp relay
Aftermarket AC relay
Possibly tow package relay or CB relay???
Re: What IS this? (71 E-Body firewall thingy) [Re: HairOtheDog] #1517916
10/15/13 05:24 PM
10/15/13 05:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
NOX valve
That style was used in 71 and I think part of 72.
Re: What IS this? (71 E-Body firewall thingy) [Re: ConvertiBee] #1517917
10/15/13 05:35 PM
10/15/13 05:35 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Re: What IS this? (71 E-Body firewall thingy) [Re: burdar] #1517918
10/15/13 06:07 PM
10/15/13 06:07 PM
Wow! Okay... Holy Heck! I live right here in the land of "We're gonna take away all of your gun rights", and I've never even seen one before. This would probably tie into the "N98- Exhaust Emissions Standards Label" on my fender tag, which I had no idea what that was either.
THANKS! ... I'll just coil that wire up neatly and tie-wrap it near that unit
'72 Cuda 340 FE5
Re: What IS this? (71 E-Body firewall thingy) [Re: ConvertiBee] #1517919
10/15/13 08:07 PM
10/15/13 08:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup I put mine back after rebuild because there's a hole under it. It also has a speed sensor in the speedo cable and that's where the wire goes in the trans tunnel. It also pulled timing out also or added it?
