77 dodge 4x4 lost all electical power #1517611
10/14/13 08:22 PM
10/14/13 08:22 PM
Fredericton NB Canada
471b1dart Offline OP
Im working on a guys 77 dodge 4x4 , drove it in shop turn it off , went to move it and now it has no power to anything , no lights , radio , starter nothing , could it be the starter relay were the battery pos goes or more likely the ammeter gauge conection??
Re: 77 dodge 4x4 lost all electical power [Re: 471b1dart] #1517612
10/14/13 08:30 PM
10/14/13 08:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
check for bad connections at the bulkhead connector, burnt fuseale links, dead batt..
I am truckless..
Re: 77 dodge 4x4 lost all electical power [Re: 340SHORTY] #1517613
10/14/13 08:42 PM
10/14/13 08:42 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 77 dodge 4x4 lost all electical power [Re: 340SHORTY] #1517614
10/14/13 08:46 PM
10/14/13 08:46 PM
Battery is new , connections all seen tight and clean at bulk head , fuseible links dont look burned ??
Re: 77 dodge 4x4 lost all electical power [Re: 471b1dart] #1517615
10/14/13 09:28 PM
10/14/13 09:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check the ammeter. Pretty basic simple system. A test light and a couple of minutes and I could find the problem.
Re: 77 dodge 4x4 lost all electical power [Re: 471b1dart] #1517616
10/14/13 10:51 PM
10/14/13 10:51 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Try tugging on the fuseable links... If they are stretchy they are probably bad.
Sometimes they will melt inside, and not look bad from the outside.
And I agree with the test light.
